You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2280) English
Posted by: tyzio | Date: 2007-10-02 12:03 | IP: IP Logged
One more hint which I found today concerning LOG output window.
When I disabled "Follow compilation log" in Projects->Projects settings...", the problem is visible rarely and somehow different than before. (At first time only one or two lines are displayed badly (strange character instead of correct information) and after start scrolling rest information gets unreadable.
I hope you find this information useful.
Posted by: valval | Date: 2007-10-02 23:49 | IP: IP Logged
CmputrAce:What I still want:
* Code folding
* Subversion integration
Definitely the only 2 missing features in this awesome program.
Jan what do you say about it?
Posted by: pspad | Date: 2007-10-03 03:42 | IP: IP Logged
Base editor component doesn't support Code folding yet.
CVS solution you can find in the forum.
Posted by: Programmer | Date: 2007-10-03 19:04 | IP: IP Logged
Just unpacked 2280
Editor still broken
Can we at least get the toolbar thing fixed?
When I open PsPad, there are blank spaces in the middle of the toolbar. If I double click the bar on the rightmost segment they autofit. If I close it and reopen, spaces are back.
Also, if I open a file in PsPad using File>Recent or File>Open, then close PsPad and reopen it, the files I last had open are reopened. Then if I open another file by double clicking on it in Windows Explorer and reopen PsPad, that file does not reopen. Is that intentional, or can you fix that?
Thanks.
Posted by: valval | Date: 2007-10-03 19:33 | IP: IP Logged
pspad:Base editor component doesn't support Code folding yet.
Are there any plans to support it any time soon?
I know there are some plug-ins for Subversion (not CVS!) support, but they are old and rather limited and buggy. I think most people using the editor to write code use or have access to Subversion repositories, so it would be nice to integrate this feature
Posted by: Nilpohc | Date: 2007-10-03 19:45 | IP: IP Logged
Hi !
I'm experiencing crashes when using Tidy functions (from the HTML menu). Rolled back to build 2777 which is ok...something broken in this one ?
Still the best editor anyway
Posted by: pspad | Date: 2007-10-04 04:07 | IP: IP Logged
There is a problem in the latest build.
Posted by: Programmer | Date: 2007-10-04 13:19 | IP: IP Logged
valval:pspad:Base editor component doesn't support Code folding yet.
CVS solution you can find in the forum.Are there any plans to support it any time soon?
I think most people who would use this editor like the fast load time and don't need cvs/subversion support, so if it is added it should be an optional add-on.
I like the idea of code folding. It should be added as an optional add-on if it significantly affects editor speed. It should have options to set string values for start and end fold markers.
Posted by: mahira | Date: 2007-10-05 03:19 | IP: IP Logged
A quick build will be kindly appreciated
regards,
Mahir
pspad:There is a problem in the latest build.
Posted by: himila | Date: 2007-10-05 20:02 | IP: IP Logged
hi, one bug in the 2280 version.
whenever you select chinese or english language for pspad, then when you click format--font,you will see the dialog box still dispaly in chinese language(maybe because i use the chinese os.) , and whatever you click(OK or CANCEL) it still will get application error, say
Exception description:
Access violation at address in module 'PSPad.exe'.
Read of address .
Exception class:
Exception address:
Stack list, generated 2007-10-6 星期六 4:01:24
Edit by mod:
By an advice of the author!
Hello, thanks for the report, but please
do not post such "Access violation" logs into the forum,
but post only an hint that you have this error
and send the error log itself to the Author Jan by email! (sup p ort - a't - pspad - c0m)
Thanks for the report and your comprehension.
The mod.
Program : E:\pg\pspad\PSPad.exe 4.5.3 (2280)
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 2"
Processor: AMD, AMD Athlon(tm) , 2000 MHz MMX
Display : 1024x768 pixels, 32 bpp
Active Controls Hierarchy:
Edited 1 time(s). Last edit at 2007-10-05 20:23 by Stefan.
