You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2277) English
Posted by: mahira | Date: 2007-09-27 19:45 | IP: IP Logged
+1
pypardo:...PsPad is *really* the best text editor...
...Best regards
pierre
Posted by: mica | Date: 2007-09-28 16:17 | IP: IP Logged
I had to register in this forum to say that this editor is best, like those say also.
Thank you Jan very much this excelent editor!
Posted by: hankejh | Date: 2007-09-28 16:26 | IP: IP Logged
pspad:mahira:It looks a bit heavy work but I think that the "final" solution is to change the edit componentScintilla is much more "programmer friendly" than SynEdit.
You are right, it's big deal. I am deciding to release full version now and work on the "new" PSPad with new base.
Scintilla is black box for me - DLL. I don't know, if scintilla is unicode - I don't think.My last favourite is PlusMemo component. I tested it and I like it.
Sounds like it is time for PSPad lovers to make a donation toward Jan's work on implementing a new editor base.
Posted by: troydtx | Date: 2007-09-28 19:16 | IP: IP Logged
1st let me say that I LOVE PSPad. I have been using it as my main editor for JSP, HTML, CSS etc. for at least a couple of years - so much that I made a donation a while back. Your efforts are very much appreciated!
I don't know all the issues involved with building around a new editor component (I'm sure it is a HUGE job), and I'm not a "windowws application" programmer at all.
But I do think Scintilla is fully Unicode enabled. "basic" Unicode for several years - latest release (1.74) now says "Unicode support extended to all Unicode characters not just the Basic Multilingual Plane".
Even though PSPad is my main editor, I do like the Scintilla-based editor Notepad++ (it's the only other editor that i also use regularly).
And I don't know how much it would help, but I just noticed a sourceforge project called "Delphi Scintilla Interface Components" (delphisci.sourceforge.net) which says it:
Quote:is a FREE collection of components that makes it easy to use the
Scintilla source code editing control from within Delphi, C++ Builder and BDS (Win32 Mode).
Thanks again for your fantastic program!
Edited 1 time(s). Last edit at 2007-09-28 19:43 by troydtx.
Posted by: naputtelija | Date: 2007-09-29 06:53 | IP: IP Logged
With Scintilla we would lose hmtl multihighlighter. Scintilla has much more limited support for different syntaxes in same file. For me this is much more important than code folding.
Posted by: hankejh | Date: 2007-09-29 16:47 | IP: IP Logged
naputtelija:With Scintilla we would lose hmtl multihighlighter. Scintilla has much more limited support for different syntaxes in same file. For me this is much more important than code folding.
I agree - code folding would by convenient, but losing multihighlighter is an unacceptable loss for me.
While my experience extending PSPad is limited to two script extensions, I believe that code folding could be implemented with scripting and that it would amount to less work than rebuilding on a new editor foundation. Think I'm crazy?
Posted by: andybridges | Date: 2007-10-01 14:54 | IP: IP Logged
I've been using PSPad for several years now but would rapidly have to move away if we lost the multihighlighter. That said I'm confident Jan would never go with a code folding component if it meant loosing the multihighlight abilities, so I'm not that worried.
Oh and hankejh...
hankejh:I believe that code folding could be implemented with scripting ... Think I'm crazy?
Yes. Yes, I do.
Posted by: hankejh | Date: 2007-10-01 15:49 | IP: IP Logged
andybridges:Oh and hankejh...hankejh:I believe that code folding could be implemented with scripting ... Think I'm crazy?Yes. Yes, I do.
Uh oh.. Where's the "worried smiley"??
Posted by: pspad | Date: 2007-10-02 07:06 | IP: IP Logged
I will rewrite LOG window because I am not able to test ii over all possible hardware and software combinations.
There is a problem with drawing.
OK. Now is it ready.
owner draw methods for highlight errors and warnings was replaced by bookmarks, was replaced internal methods for adding line into LOG. I hope next build will be OK
Edited 1 time(s). Last edit at 2007-10-02 09:52 by pspad.
