You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2259) English
Posted by: pspad | Date: 2007-03-03 13:16 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.3 (2255)
News
all PSPad dialog style was changed from ToolWindow to the standard Dialog form. It should remove problems with application switching, double PSPad window in some taskbar replacement e.t.c.
internal HTML highlighter has possibility to define own windows sizes in wwwtools.ini file
interactive template window set width to the longest caption
Scripting support - new function getVarValue(variable[, filename]: string): string. It returns value of any PSPad variable. Second paramater is optional, is used fo filename related variables
Scripting support - new function pspadPath returns path to PSPad exe include last delimiter
Remove redundant spaces dialog remembers setting during PSPad session
Insert text to lines dialog - possibility skip empty lines
Option Copy non matched in Search dialog is back
Newly created FTP connection is highlighted after Copy FTP settings function
partialy speed-up text reformat function, added progressbar
in the [Special setings section] added variable MultiHLUpToSize to determine max. file size in bytes for multihighlighter
Eyedropper takes color from whole desktop, not from primarry monitor only
Corrections
Log color respect editor colors
Cobol Code Explorer works with AREA highlighter settings
drawing - some chars artefacts after wordwrap
some UNDO corrections
problem with System resources on Windows 9x
Text differences - nonnumbered bookmarks wasn't visible
user highlighter for Verilog
Auto completion window position was behind screen edges in some cases
handled PSPAD.EXE in Hex editor problem after start
Code explorer for AutoHotkey - functions
Internal HTML preview and VBScript - HTML envelop was inserted
Interactive templates - checkbox ignores delimiter settings
HTML Code explorer and TBODY element
Program settings - incorrect value was set for file tab style
Reload functions resets highlighter to default
Posted by: jgodfrey | Date: 2007-03-03 14:26 | IP: IP Logged
Hi Jan,
I just grabbed the new 2259 from the posted link. While many files in the archive have a date stamp of 3/3/2007, the actual PSPad executable has a date stamp of 2/4/2007, and seems to be version 2255?
Jeff
Posted by: Mario | Date: 2007-03-03 14:27 | IP: IP Logged
The archive contains PSPad.exe build 2055 (4th February).
Posted by: pjj | Date: 2007-03-03 14:28 | IP: IP Logged
I'm sorry to rain on your parade, but seems like you put 2255 exe into this cab...
Posted by: pspad | Date: 2007-03-03 15:36 | IP: IP Logged
I am sorry. This was my mystake. Correct build is in place
Posted by: pjj | Date: 2007-03-03 21:14 | IP: IP Logged
Many thanks for the new build!
Posted by: mc | Date: 2007-03-04 20:28 | IP: IP Logged
i'm unable to download the file. connection refused
Posted by: drkokr | Date: 2007-03-04 21:30 | IP: IP Logged
drkokr
- Windows8.1 x64, i5-750, 8GB RAM, PSPad 4.6.0 (2661), dvě ruce a klávesnice, (občas mozek a sem tam hlava)
Posted by: fetis | Date: 2007-03-05 07:54 | IP: IP Logged
Thanks for selecting last created FTP connection, but
the FTP connection window is not resizeable!!! It's terrible :((
Posted by: naputtelija | Date: 2007-03-05 09:32 | IP: IP Logged
Word wrapping is broken in HTML comments
Easy to verify:
<html>
long enough line, add some more text and you will see
</html>
