You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2249) English
Posted by: menet | Date: 2006-12-18 14:38 | IP: IP Logged
janpaul:peter4rd:Yes with 2249 new files now start showing column 2.I tried both the new file and the sendto and in both cases the starting column is column 1, so no problem over here.
WinXP Pro Dutch, Bitstream Vera Sans Mono font, build 2249.
There is no problem with the file, it is only the showing which begin in column 2 in some cases. Doing home permits to see the first column which is always good with 2249
I suppose that Jan has also encountered the problem and will correct that in the next version
Best regards
Posted by: Xandros | Date: 2006-12-19 06:17 | IP: IP Logged
Would be very nice if it was possible to only have "pspad" on the shell context menu and be able to remove "pspad hex" and "pspad diff" in some way, i searched through the registry but it seems to be contained in a DLL so ... I was thinking about options on what to show or not, like in WinRar and WinZip shell context menu ...
Posted by: Jan Paul | Date: 2006-12-19 08:27 | IP: IP Logged
menet:janpaul:peter4rd:Yes with 2249 new files now start showing column 2.I tried both the new file and the sendto and in both cases the starting column is column 1, so no problem over here.
WinXP Pro Dutch, Bitstream Vera Sans Mono font, build 2249.There is no problem with the file, it is only the showing which begin in column 2 in some cases. Doing home permits to see the first column which is always good with 2249
Best regards
Thanks Yes, I know. Column 1 is showing ok on my systems... So I still cannot replicate this problem.
But since Jan found the problem, enough said about this.
