You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2249) English
Posted by: pspad | Date: 2006-12-10 19:26 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.3 (2247)
News
scripting support - new function inputText(prompt, default_value: string): string
File explorer - added possibility to move to parent folder
Code explorer toolbar icons was unified with used icon set
Code explorer - open content in new file
Save file to FTP - PSPad wouldn't reload file list if file already exists
Corrections
file tab doesn't corespond to file if file was close via the file tab context menu
editor doesn't scroll to cursor if keypress doesn't move cursor (e.g. Left arrow when cursor was on the line begin)
Code explorer for VHDL - processes
Sarch in files - initial focused control
Python highlighter and multiline strings
Posted by: _meta_ | Date: 2006-12-11 10:00 | IP: IP Logged
Just one note:
Ctrl+Tab in z-order is still broken
Posted by: Maleval | Date: 2006-12-11 11:38 | IP: IP Logged
Posted by: Maleval | Date: 12/11/2006
Just installed 2249.
Got this error when I right-click on a tab to close a file.
Note that it happens only when there's only one last tab to close.
Exception class:
Exception address:
Stack list, generated 11/12/2006 12:31:24
Edit by mod:
By an advice of the author!
Thanks for the report, but please
do not post such "Access violation" messages into the forum,
but post only an hint that you have this error
and send the error log itself to the Author Jan by email! (sup p ort - a't - pspad - c0m)
Thanks for the report and your comprehension.
The mod.
Program : C:\Program Files\PSPad editor\PSPad.exe 4.5.3 (2249)
System : Windows XP Home Edition, Version: 5.1, Build: A28, "Service Pack 2"
Processor: Intel, Intel(R) Pentium(R) 4 CPU 3.60GHz, 3580 MHz MMX
Display : 1280x1024 pixels, 32 bpp
Edited 1 time(s). Last edit at 2006-12-16 13:41 by Stefan.
Posted by: MrSpock | Date: 2006-12-11 12:12 | IP: IP Logged
Yes, same here. Closing last tab via right-click causes an access violation.
Posted by: Anonymous User | Date: 2006-12-11 13:26 | IP: IP Logged
Confirmed.
Posted by: gia | Date: 2006-12-11 15:48 | IP: IP Logged
Thank you for the new build.
Maybe there is a good reason for that, but the HTML checker looks disabled in my installation, it was working in the previous build.
HTML -> Check HTML code - Ctrl+F10
The menu entry is greyed and the shortcut does nothing.
Great editor!
Cheers,
Giacomo
Posted by: zdub | Date: 2006-12-11 16:20 | IP: IP Logged
Also got the access violation but it doesn't seem to adversely affect pspad (doesn't crash it.) Anyway, I wouldn't have even thought to do a right-click/close; I prefer the must easier and more efficient scroll-button click tab (or double-click tab).
Posted by: MHS | Date: 2006-12-11 17:24 | IP: IP Logged
In this version, the dictionary is working again. Thanks.
Posted by: pspad | Date: 2006-12-11 17:28 | IP: IP Logged
gia:Thank you for the new build.Maybe there is a good reason for that, but the HTML checker looks disabled in my installation, it was working in the previous build.
Great editor!
Cheers,Giacomo
Tidy.EXE must exists in the PSPad folder and file have to be a HTML like
Posted by: giaco | Date: 2006-12-12 10:22 | IP: IP Logged
pspad:gia:Thank you for the new build.Maybe there is a good reason for that, but the HTML checker looks disabled in my installation, it was working in the previous build.
Great editor!
Cheers,Giacomo
I opened a html file and chose html highlighter, but it's greyed. Tidy.exe exists in pspad folder, I didn't touch it.
I tried to uninstall and make a 5.2 fresh installation and it worked again. Then I reupdated to build 2249 (just extracted the files in pspad folder) and it's not working again.
Maybe it's just my installation? I've never posted in the forum but I've been using almost every beta build since 5.0 without any problem.
PSPad is my favourite editor! As it is for many people
