You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.3 (2247) English
Posted by: raeubi | Date: 2006-11-29 07:46 | IP: IP Logged
Several translation (minor) issues:
In menue Tools - Macro
Ihe most of that item are in Cesky,
however the icons give any help
Posted by: pspad | Date: 2006-11-29 07:59 | IP: IP Logged
Thank you
Posted by: jdoe2006 | Date: 2006-11-29 09:55 | IP: IP Logged
I am facing an erroneous behaviour of pspad when it comes to highlighted printing of SQL-files.
Ah, just in case, you need the source I have it included into this post also.
COMMENT ON TABLE "IdentifierMapping" IS '
In this context a mapping is defined between two 2-tuples making of the source and destination part respectively. The first element of each tuple is the identifier of the provider that is "responsible" for the data. The second component is the respective station identifier in the provider''s internal reference system. Let''s have a look at an example: (p,s)->(p'',s'') means that the station s from provider p is mapped into the reference system of provider p'' where it is identified by s''.;
That's what print preview does (and is actually printed).
Edited 3 time(s). Last edit at 2006-11-29 09:59 by jdoe2006.
Posted by: MoeGreene | Date: 2006-11-29 14:36 | IP: IP Logged
Switching between previous and next window doesn't seem to work. I haveaSelectPrew=Alt+Up
andaSelectNext=Alt+Down
in my keymap.ini but only Select previous using Alt+Up works. When I press Alt+Down I get the same result as pressing Alt+Up.
Posted by: pspad | Date: 2006-11-29 16:15 | IP: IP Logged
MoeGreene:Switching between previous and next window doesn't seem to work. I haveaSelectPrew=Alt+Up
Disable smart file switching (option in program settings)
Posted by: pypardo | Date: 2006-11-30 08:01 | IP: IP Logged
I discover a strange feature in this new build (but I can't ensure it do not exist in previous).
After using pspad for a while, pspad cursor don't visually appears at the right position.
I explain what I see:
1/ I start a new line by pressing 'enter' key.
2/ Cursor is at the right position (at the begining of the line)
3/ I press 'tab' key
4/ Cursor is not at the right position because it is still at the begining of the line, but cursor position (displayed at the bottom of screen) is right !
5/ I type a text, this text appears at the right position (after a tab)
This problem does not appears all the time. I'll try to make some screenshot next time I encounter it.
Best regards
pierre
Posted by: henrikca | Date: 2006-11-30 08:50 | IP: IP Logged
After applying 2247 spell checking doesn't work. Getting this error: Dictionary "English.2-1-0" not found. It used to work without problems in 2246 and the file
C:\Program Files\PSPad editor\Spell\English.2-1-0.dic
is still there.
Posted by: pspad | Date: 2006-11-30 09:28 | IP: IP Logged
henrikca:After applying 2247 spell checking doesn't work. Getting this error: Dictionary "English.2-1-0" not found. It used to work without problems in 2246 and the file
is still there.
Ctrl+F7 (Spell settings) and choose English
Posted by: PGomersall | Date: 2006-11-30 15:06 | IP: IP Logged
Jan,
I have exactly the same spell problem - "Dictionary "English.2-1.0" not found (on multiple machines). English is the only available choice in Spell settings dialog. Get the same error after going to the Spell settings dialog. Only OK, Cancel and "Download from Internet" buttons are active not reload.
I found that the problem is still the hard-coded pointer to C:\Program Files\Common Files\SynSpell mentioned on the 2246 thread. I am running Vista on a dual boot - Vista is on V: PSPad is in default on V:, putting the dictionary in C:\Program Files\Common Files\SynSpell makes PSPad dictionary work (and the "Reload" button become active) - but obviously not correctly.
I also cannot get auto correct to work e.g. put in tss and test, type tss and space - no correction?
Pete
Edited 4 time(s). Last edit at 2006-11-30 15:34 by PGomersall.
Posted by: Thomas Milo | Date: 2006-12-02 14:24 | IP: IP Logged
>Hi,
>line) 3/ I press 'tab' key
>at the bottom of screen) is right ! 5/ I type a text, this
If it just happens in one editor window, then it is likely to be one bug I already described here:
forum.pspad.com
see under "It has a very weird caret bug."
