You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.3 (2244) English
Posted by: henning | Date: 2006-11-15 14:31 | IP: IP Logged
So what about a "bugzilla" (or an likewise product) for PSPad?
Is there someone who can set up a bugzilla Site for this great editor? We than can all look up in the bugzilla database if our bugs can be reproduced, will be analysed and so on... and the developer has more time for developing...
Precondition is, the PSPad developer is willing to work with the tool...
Henning
Posted by: pspad | Date: 2006-11-15 15:12 | IP: IP Logged
I was thing about some bug reporting system. But I have no time to study and set it
I found a produkt I like:
www.mantisbt.org
Posted by: Eblis | Date: 2006-11-16 07:26 | IP: IP Logged
I also think that mantis is a better choice over bugzilla
Posted by: Instinct | Date: 2006-11-16 07:41 | IP: IP Logged
If you're working with Subversion, trac is a very nice bug tracking/wiki combination
Posted by: pspad | Date: 2006-11-16 08:00 | IP: IP Logged
Instinct:If you're working with Subversion, trac is a very nice bug tracking/wiki combination
I am not working with a subversion and I don't plane it.
Posted by: ArKay | Date: 2006-11-16 15:19 | IP: IP Logged
Eblis:I also think that mantis is a better choice over bugzilla
Mantis is a great choice! Bugzilla is intimidating.
Posted by: Stealth | Date: 2006-11-19 10:16 | IP: IP Logged
Hi Jan,
1) I have top style (full) and i can't integrate it with pspad because the default is top style lite. Is it possible top style integration into pspad? Where is the ini settings?
2) I use smarty template for php; how can view smarty syntax highlighter in html multihighlighter mode?
Thank you for the greater work!
Posted by: pspad | Date: 2006-11-19 12:08 | IP: IP Logged
1. Authors of the TopStyle allows integrate Lite version only. It's no PSPad limitation but TopStyle limitation.
2. PSPad allows you highlight embeded PHP, not some specialities in PHP like Smarty. I don't know smarty. Can you tell me some examples of Samrty in PHP ?
Posted by: Stealth | Date: 2006-11-19 13:20 | IP: IP Logged
This is an example:
<SPAN class="{$color_cf}">Cod: </SPAN>
{if $prev eq "ok"}
<span class="testonero">{$cf_prod}</span><input name="cf_prod" type="hidden" value="{$cf_prod}" size="25" maxlength="16">
{else}
<input name="cf_prod" type="text" id="text_cf_prod" value="{$cf_prod}" size="25" maxlength="16">
</td>
</tr>
<input name="tipologia" id="tipologia" type="hidden" value="PS" size="2">
</td>
</tr>
{/if}
Smarty is the most important template engine in php that allows separation between html code (view) and php code (model & controller)
{if $prev eq "ok"}
then html code will be: <span class="testonero">{$cf_prod}</span><input name="cf_prod" type="hidden" value="{$cf_prod}" size="25" maxlength="16">
else the html code will be:
</td>
</tr>
</td>
</tr>
The: {if $prev eq "ok"}, {else} and {/if}, {$cf_prod}..etc.. is smarty syntax embedd in html code
Posted by: carbonize | Date: 2006-11-19 14:12 | IP: IP Logged
Basically smarty is shorthand.
For example
{if $a == $b}
is just the same as using
<?php
if ($a == $b)
and
{else}
is just shorthand for
<?php
} else {
Carbonize
