You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2240) English
Goto Page: Previous1 2 3
#21 Re: Code-Explorer and CSS
Posted by: freeb0rn | Date: 2006-10-31 06:05 | IP: IP Logged
There seems to be something wrong with the tabs.
Go into Program Settings
-> Program Behavior
-> Uncheck smart file switching
Try to CTRL+Tab or SHIFT+CTRL+Tab, the "tab" will change but the file in the "editor window" will not.
Also, if you try to SHIFT+CTRL+TAB with smart file switching checked, it does the same thing.
#22 Re: Code-Explorer and CSS
Posted by: freeb0rn | Date: 2006-10-31 06:06 | IP: IP Logged
freeb0rn:
-> Program Behavior
Nevermind, I tried replicating this and couldn't for some reason (although I did so twice yesterday). I'm not sure what I am missing.
#23 Re: PSPad unicode 4.5.2 (2240) English
Posted by: tyzio | Date: 2006-10-31 20:59 | IP: IP Logged
Hi Jan,
Thanks for this release.
Anyway, some problems which I reported for 4.5.2 b2238 are still in:
- Indent/Unident doesn't work for single line without any selection
- Check spelling: The underline disappers when user clicks on underlined word when wrap line is ON
- Check spelling stops working for *.txt files at all in some scenarios, e.g.:
1. PsPad is running
2. Open some *.txt file
3. Enable spell check-underlineing via PsPad toolbar -> works OK.
4. Close the file and open again -> Enable spell check-underlineing via PsPad toolbar -> stops work at all, PsPad needs to be reseted.
Sometimes PsPad crashes when I try to disable/enable spell check again. The produced crash log will be mailed to you.
Edited 1 time(s). Last edit at 2006-10-31 21:19 by tyzio.
#24 Re: PSPad unicode 4.5.2 (2240) English
Posted by: pspad | Date: 2006-10-31 21:24 | IP: IP Logged
For Indent / Unindent in one line use TAB / Shift+Tab (you can use it for selected block too)
I know problem with SpellCheck and Wordwrap, but I have no solution yet.
#25 Re: PSPad unicode 4.5.2 (2240) English
Posted by: tyzio | Date: 2006-10-31 22:08 | IP: IP Logged
Thanks for such quick response.
Yes, it is solution but you need to go back to the beginning of the current linegrinning smiley
Cool, I'm looking forward for this fix.
One more think: I found that in LOG parser expression the char * doesn't match the space (0x20) char and it should match everything.
I found it because I try to parse the output from my compiler which align right the line numbers (bellow I replace spaces with _ for better view):
Line___67: W Unknown command "putss"
Line__211: W Unknown command "putss"
Line_2189: W Unknown command "putss"
Right now I'm not able to parse all 3 cases, I try:
Line*%L:*
*%L:*
*%L:%E
#26 Re: Code-Explorer and CSS
Posted by: pspad | Date: 2006-11-02 19:54 | IP: IP Logged
phoenix:
thx for the update - a great editor. smiling smiley
One thing I found out in the codeexplorer. If you write your css-code like this:
#example1,
#example2,
#example3
the codeexpl. will show you:
- #example3 (...nothing more)
If you write it like this:
#example1, #example2, #example3
all ID's are visible in the codeexpl.
Bug or Feature?
phoenix0107
it's given by desing. Code explorer parse line by line. It doesn't handle all possible variants of code.
#27 Re: Code-Explorer and CSS
Posted by: phoenix0107 | Date: 2006-11-07 08:35 | IP: IP Logged
phoenix:
#example1,
#example2,
#example3
Bug or Feature?
phoenix0107
okay, thanks for the answer smiling smiley
#28 Re: Code-Explorer and CSS
Posted by: pspad | Date: 2006-11-07 13:27 | IP: IP Logged
phoenix0107:
phoenix:
#example1,
#example2,
#example3
Bug or Feature?
phoenix0107
Download the latest build, it's already implemented
