You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2187) English
Posted by: pspad | Date: 2006-03-06 06:36 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.1 (2185)
News
new function in the Edit menu/Line manipulations - Swap with line Above
program settings / Dialogs - option allows you switch off FTP replace file confirmation
Methods support in the Tcl/Tk highlighter
Corrections
Search in files results highlight and Ignore case setting
Search in files adds BOM into UTF-8 files
Code explorer for PHP - accented chars support in the variables
Extended copy doesn't works with the last line
Find/Replace dialog - replace confirmation
PSPad doesn't respect individual TabWidth for highlighters
function CloseAll closes project files too without confirmation
Posted by: Replika | Date: 2006-03-06 07:23 | IP: IP Logged
Function Search/Replace in Files breaks utf8 chars when replacing, although choose UTF8 in Files Code page. (Like problem of former Extended Cut & Copy )
Test with Punbb lang
Post Edited (03-06-2006 08:26)
Posted by: pspad | Date: 2006-03-06 08:08 | IP: IP Logged
This is problem of the display reults windo only, not the problem of replacing process
Posted by: Replika | Date: 2006-03-06 08:30 | IP: IP Logged
Quote:This is problem of the display reults windo only, not the problem of replacing process
No, it corrupts my files, you can see in the screenshoot.
Post Edited (03-06-2006 09:31)
Posted by: pspad | Date: 2006-03-06 08:43 | IP: IP Logged
I test is with cyrilic (Russian) chars.
Can you send me your file ?
Posted by: Jume | Date: 2006-03-07 04:13 | IP: IP Logged
stupid question of the day, having new options to switch lines, the old string is now outdated and can be deleted safely, i guess
[edited]
nevermind, is not in the english file already, i should just shut up now and go steady to the corner
Post Edited (03-07-2006 05:16)
Posted by: pspad | Date: 2006-03-07 04:47 | IP: IP Logged
There arn't in any language files in laetst PSPad package
Posted by: DJ N-4ceR | Date: 2006-03-07 08:49 | IP: IP Logged
I use the FTP function of PSPad very often in conjunction with Perl. Would be nice to have a context menu like -> chmod -> GUI / 644 / 755
Posted by: pspad | Date: 2006-03-07 10:52 | IP: IP Logged
And there isn't CHMOD GUI in the context menu ?
Posted by: jgodfrey | Date: 2006-03-07 15:05 | IP: IP Logged
Hi Jan,
As always - thanks for the PSPad update. You just keep improving upon an already great piece of software!
It seems that 2187 still has the "blocking" problem I mentioned several times in the recent past, in at least the following 2 messages:
and
The changelog of 2187 didn't mention a fix, so I wasn't expecting one, but I'm still trying to determine if the problem is a *setting* within PSPad that I have wrong, or if it is a problem with the 4.5.* builds.
If possible, could you either acknowledge it as a problem ( so I quit pestering you ), or tell me what option(s) I should try to change to fix it?
Thanks,
Jeff
