You are here: PSPad forum > Developer forum - new builds > PSPad 4.3.3 (2089) update English
Posted by: pspad | Date: 2005-06-29 18:41 | IP: IP Logged
Download link: pspad.cincura.net (1.3 MB)
Notes to PSPad update versions:
this CAB archive contains PSPad.EXE only. Replace existing file from 4.3.3 version
Jan
Posted by: johan | Date: 2005-06-29 19:49 | IP: IP Logged
And the additions/changes are?
Thanks a bunch for this great editor!
Posted by: pspad | Date: 2005-06-29 19:58 | IP: IP Logged
I have no power for it already
Some small corrections from last update:
problem with recent files
end of PHP detection after ?>"
Posted by: Leif Gregory | Date: 2005-06-30 16:49 | IP: IP Logged
Still not fixed for end of detection on ?> for PHP
See below snippet:
<tr><td>
<table align="center" width="55%">
<tr><th class="innercell" align="center">Are you sure you want to delete the entry?</th>
<tr><td align="center"><input type="submit" name="deleteIt" value="Yes"> <input type="submit" name="cancel" value="No"></td></tr>
<tr><td><input type="hidden" name="tabID" value="<?php echo $tabID;?>"><input type="hidden" name="recordID" value="<?php echo $_GET['delete'];?>"></td></tr>
</table>
</td></tr>
Make sure HTML Multi-highlighter is turned on. After $_GET['delete'];?> the closing td, tr, table, td, tr are incorrectly highlighted.
Thanks for a great program though! <Grin>
I can provide many more examples if needed.
Leif Gregory
Computers and TheBat!: www.PCWize.com
PHP Programming: www.DevTek.org
Posted by: pspad | Date: 2005-06-30 16:56 | IP: IP Logged
Write regular expression whot in line
detect end of PHP script and will count with all possible variants, escaped...
Posted by: Jume | Date: 2005-07-01 00:43 | IP: IP Logged
ahem, not that i want to be a bother but...
to leif and anybody... something totally off-topic...
you do...
not that i am a guru of php or so, but, i do, and i recommend to do...
value="<?=$_GET['delete']?>">
which is shorter and php has it there just for that purpose
Posted by: nTE | Date: 2005-07-01 10:13 | IP: IP Logged
But this works only if short tags are enabled which is not given on every server.
So if you want to write redistributable code which runs on more than just your machine, don't use short tags.
Posted by: flor | Date: 2005-07-01 10:53 | IP: IP Logged
Hi!
I think you should stop fighting with ?> inside quotes, which i suppose makes problems mentioned by Leif Gregory,
because:
- it's not used often and here's simple workaround:
problem: 'text ?> text';
ok: 'text ?'.'> text';
- it's causes problems with ?> ending, which is used more frequently
