You are here: PSPad forum > Translation > Re: Simplified Chinese (ChineseGB)
Posted by: QWERT | Date: 2023-12-02 02:25 | IP: IP Logged
5.5.1 (812)
Posted by: pspad | Date: 2023-12-02 12:29 | IP: IP Logged
Thank you
Posted by: QWERT | Date: 2026-04-17 15:45 | IP: IP Logged
5.5.2(843)
Posted by: QWERT | Date: 2026-08-01 07:49 | IP: IP Logged
5.5.2(845)
Posted by: QWERT | Date: 2026-08-21 14:46 | IP: IP Logged
5.5.3(857)
Posted by: QWERT | Date: 2026-08-27 08:32 | IP: IP Logged
5.53(861)
Posted by: QWERT | Date: 2026-09-26 05:14 | IP: IP Logged
5.53(873)
Posted by: QWERT | Date: 2026-10-21 09:16 | IP: IP Logged
For 5.53(883)
; ChineseGB localization for PSPad text editor v5.5.3(883)
; Translation: Alex@Ajoyoo <''.phorum_html_encode('thinkscape@hotmail.com').''>
; www.pspad.com, mailto:''.phorum_html_encode('support@pspad.com').''
[Author]
Name=Alex Chen (Dothink) & 大眼仔~旭(Anan)(Update)
E-mail=''.phorum_html_encode('thinkscape@hotmail.com').'' & ''.phorum_html_encode('wcxu21@126.com').''
WWW=http://www.dayanzai.me
[Common]
DefaultFont=MS Shell Dlg
[Action List]
aAbout_Caption=关于...
aAbout_Hint=PSPad 相关信息
aAddDiacritic_Caption=添加重音符号
aAddFile_Caption=添加文件到工程
aAddFile_Hint=添加文件到工程
aAddFilesToFolder_Caption=添加文件...
aAddFolder_Caption=新文件夹
aAddFolder_Hint=在工程树中建立新文件夹
aAllToASCII_Caption=从字符中移除重音符号
aAllToASCII_Hint=移除中欧字母上头的重音符号,如 é -> e
aASCII_Caption=ASCII 表格窗口(&C)
aASCII_Hint=打开 ASCII 和符号表
aAutoCompl_Caption=自动完成
aAutoRefresh_Caption=自动刷新窗口
aBaseCalc_Caption=数字基底转换器...
aBatchCPConvert_Caption=批量编码转换...
aBlockAlign_Caption=区块对齐
aBlockCenter_Caption=居中对齐
aBlockLeft_Caption=向左对齐
aBlockRight_Caption=向右对齐
aBlockSelect_Caption=区块选择
aBlockSum_Caption=计算整个区块
aBlockToTemplate_Caption=从区块建立代码片段...
aBlockToTemplate_Hint=从选中的文本建立新片段
aBugReport_Caption=错误报告...
aCapitalize_Caption=开头大写
aCapitalize_Hint=开头字母转成大写
aCheckRecent_Caption=移除最近打开的文件清单里已不存在的文件
aClearRecentFiles_Caption=清除最近文件列表
aClipMon_Caption=剪贴板监视窗口
aClipRun_Caption=运行片段
aClipShow_Caption=显示片段
aClose_Caption=关闭文件(&C)
aClose_Hint=关闭当前文件
aCloseAll_Caption=全部关闭
aCloseAll_Hint=关闭所有打开的文件
aCMDWindow_Caption=命令行...
aCMDWindow_Hint=显示命令行窗口
aCodeExplorer_Caption=程序代码浏览器窗口
aCodeExplorer_Hint=显示/隐藏程序代码浏览器
aCodeFormat_Caption=程序代码大小写更改...
aColorSelect_Caption=颜色选择器窗口
aColorSelect_Hint=颜色选择器窗口
aComment_Caption=添加/移除批注
aCompile_Caption=编译
aCompile_Hint=运行外部编译程序来编译文件
aCopy_Caption=复制(&C)
aCopy_Hint=复制所选文本到剪贴板
aCopyFormated_Caption=复制格式化的文本
aCopyLine_Caption=复制整行
aCopyMarkedLines_Caption=复制书签行
aCSSToInLine_Caption=重新格式化成行内 CSS
aCSSToStructure_Caption=重新格式化成结构化 CSS
aCSVImport_Caption=从 CSV 导入...
aCut_Caption=剪切(&T)
aCut_Hint=剪切选取的文本到剪贴板
aDateTime_Caption=插入日期与时间
aDateTime_Hint=插入日期与时间
aDateTimeDialog_Caption=日期与时间对话框...
aDecToHex_Caption=十进制->十六进制
aDelete_Caption=删除
aDelete_Hint=删除所选文本
aDelExceptMarkedLines_Caption=删除没有书签的行
aDelFolder_Caption=移除文件夹
aDelFolder_Hint=移除文件夹
aDelMark_Caption=删除书签
aDelMarkedLines_Caption=删除带书签的行
aDelMarks_Caption=删除所有书签
aDiffFile_Caption=与此文件的文本差异...
aDiffGoto_Caption=查看来源
aDiffSame_Caption=与磁盘上的文件内容的文本差异
aDropper_Caption=颜色吸管工具...
aDropper_Hint=从屏幕像素捕获颜色
aEvalExpression_Caption=表达式计算器...
aExit_Caption=退出(&X)
aExit_Hint=退出本程序
aExitEsc_Caption=按 ESC 退出程序
aExpClipHTML_Caption=导出为 HTML 格式到剪贴板
aExpClipHTML_Hint=导出文件或选取区块为 HTML 格式到剪贴板
aExpClipRTF_Caption=导出为 RTF 格式到剪贴板
aExpClipRTF_Hint=导出文件或选取区块为 RTF 格式到剪贴板
aExpClipTeX_Caption=导出为 Tex 格式到剪贴板(&T)
aExpClipXHTML_Caption=导出为 XHTML 格式到剪贴板
aExport_Caption=导出...
aExport_Hint=导出文本为 RTF 或 HTML 格式
aFileList_Caption=文件列表
aFileTabSort_Caption=按字母顺序排序文件标签
aFilesSearch_Caption=多文件搜索/替换...
aFilesSearch_Hint=同时搜索/替换多份文件
aFindFileInProject_Caption=在工程中查找文件
aFind_Caption=搜索...
aFind_Hint=搜索文本
aFindLines_Caption=按行查找...
aFindNext_Caption=查找下一个
aFindNext_Hint=搜索下一个符合的文本
aFindPrev_Caption=查找上一个
aFindPrev_Hint=查找上一个符合的文本
aFindPrevWord_Caption=搜索文本上次出现的位置
aFindWord_Caption=搜索文本下次出现的位置
aFoldAll_Caption=折叠全部
aFoldNearest_Caption=折叠最近
aFoldlevel1_Caption=折叠第1层
aFoldlevel2_Caption=折叠第2层
aFoldlevel3_Caption=折叠第3层
aFont_Caption=字体...
aFont_Hint=更改字体
aFTPConnect_Caption=连接到 FTP...
aFTPDetachFile_Caption=从 FTP 删除文件
aFullScreen_Caption=全屏模式
aGoogleSearch_Caption=Google 搜索...
aGoogleSearch_Hint=使用谷歌在互联网上搜索
aGotoLine_Caption=跳到行...
aGotoLine_Hint=跳到所选行
aGUID_Caption=插入 GUID
aGUID_Hint=插入 GUID 到光标当前位置
aHexToDec_Caption=十六进制->十进制
aHexView_Caption=十六进制编辑模式
aHLSett_Caption=语法高亮程序设置...
aHtmlCheck_Caption=检查 HTML 代码
aHTMLCompress_Caption=压缩 HTML/XML 程序代码
aHTMLCompress_Hint=压缩 HTML /XML代码而不改变页面功能
aHTMLExractText_Caption=从 HTML 提取文本
aHTMLPrev_Caption=HTML 页面预览
aHTMLPrev_Hint=在内部浏览器中显示当前 HTML页面
aHTMLReformat_Caption=重订 HTML/XML 代码格式
aHTMLReformat_Hint=重定 HTML/XML 代码格式,使其更美观且便于阅读
aHTMLSelTag_Caption=选择标签
aIncSearch_Caption=增量查找
aIncSearch_Hint=随着你不断的输入,找到最匹配的文本片段
aIndent_Caption=区块缩进
aIndent_Hint=区块缩进
aInfo_Caption=文件信息...
aInserFile_Caption=从文件插入...
aInserFile_Hint=插入文件内容到当前光标的位置
aInsertText_Caption=将文本插入多行...
aInvertCase_Caption=大小写互换
aJoinLine_Caption=合并多行
aJoinLine_Hint=将选取的多行合并成一行
aJsonReformat_Caption=JSON 美化输出
aJsonCompact_Caption=紧凑 JSON
aLangHelp_Caption=当前文件类型所对应的帮助文件
aLastUserConvertor_Caption=执行上次使用的转换器
aLineNum_Caption=行号
aLineNum_Hint=显示/隐藏行号
aLogWindow_Caption=显示/隐藏日志窗口
aLogWindow_Hint=显示带搜索/编译/FTP连接结果的日志窗口...
aLoremIpsum_Caption=乱数假文生成器...
aLowerCase_Caption=转成小写
aLowerCase_Hint=把字母转成小写
aMacroMgr_Caption=宏管理器
aMacroPlay_Caption=播放宏
aMacroPlay_Hint=播放录制好的宏
aMacroRecord_Caption=开始/停止录制
aMacroRecord_Hint=开始/停止录制宏
aMailContents_Caption=设为 E-mail 正文
aMailContents_Hint=以活动文件作为 E-mail 正文创建新电子邮件
aMailFile_Caption=设为 E-mail 的附加文件
aMailFile_Hint=将打开文件设为 E-mail 的附加文件创建新电子邮件
aMarkDown_Caption=下一个书签
aMarkList_Caption=书签列表
aMarkList_Hint=书签列表
aMarkSelection_Caption=通过选择设置书签
aMarkUp_Caption=上一个书签
aMatchBracket_Caption=括号匹配
aMatchBracket_Hint=查找互相匹配的括号 (光标置于括号前)
aMD5Gen_Caption=HASH 生成器 (MD5,SHA1,...)
aMoveAs_Caption=移动为...
aNew_Caption=新文件(&N)...
aNewFile_Caption=新文件(&N)
aNew_Hint=创建新文件
aOpen_Caption=打开(&O)...
aOpen_Hint=打开所选文件
aOpenCopy_Caption=以新文件名打开当前文件...
aOpenFavourite_Caption=打开收藏
aOpenHex_Caption=以十六进制编辑器打开(&H)...
aOpenInNewInstance_Caption=在新实例中打开
aOpenInNewInstanceAdmin_Caption=在新实例中打开 (管理员权限)
aOpenSame_Caption=打开当前文件的只读副本
aOpenSelected_Caption=在默认应用程序中打开选定的文件
aOpenSelected_Hint=启动了文件名为所选文本的文件
aOpenWWWFile_Caption=打开网络上的文件...
aPageSetup_Caption=页面设置...
aPaste_Caption=粘贴(&P)
aPaste_Hint=将剪贴板的内容插入当前光标的位置
aPasteHTML_Caption=以 HTML 格式粘贴
aPasteNoMove_Caption=粘贴时不更改光标位置
aPrint_Caption=打印(&P)...
aPrint_Hint=打印打开的文件
aPrintPrev_Caption=打印预览(&V)...
aPrintPrev_Hint=打印预览
aPrintSetup_Caption=打印机设置...
aProjAddOpen_Caption=添加所有已打开的文件
aProjAddOpen_Hint=所有已打开的文件将会加到工程里
aProjFolderClose_Caption=关闭该文件夹的所有文件
aProjFolderOpen_Caption=打开该文件夹的所有文件
aProjFromDir_Caption=从目录建立工程...
aProjInfo_Caption=工程信息
aProjInfo_Hint=工程信息
aProjMainFile_Caption=设置成编译程序的主控文件
aProjNew_Caption=新工程...
aProjNew_Hint=打开新工程
aProjOpen_Caption=打开工程...
aProjOpen_Hint=打开现有的工程
aProjSave_Caption=保存工程
aProjSave_Hint=保存已打开工程的设置
aProjSaveas_Caption=另存工程为...
aProjSaveas_Hint=以新名称保存打开工程的设置
aProjSettings_Caption=工程设置...
aProjShow_Caption=工具面板
aProjShow_Hint=显示/隐藏工具面板
aProjSynchroDrive_caption=与驱动器内容同步
aProjSynchroDrive_Hint=将工程内容与驱动器内容同步
aReadOnly_Caption=只读
aReadOnly_Hint=将文档设成只读
aRedo_Caption=恢复
aRedo_Hint=恢复上次撤销
aReformat_Caption=重订格式 (段落=空白行)
aReformat_Hint=用右边界的设置重订文本块格式
aReformat2_Caption=重新格式化 (段落=短列)
aReformat2_Hint=根据右边界设置重新格式化选取的区块文本
aRegistr_Caption=首选项...
aRegistr_Hint=打开首选项对话框
aRemoveBlankLines_Caption=移除空白行
aRemoveDuplicities_Caption=删除重复行
aRemoveDuplicitiesCI_Caption=删除重复行 (区分大小写)
aRemoveFile_Caption=从工程中移除文件
aRemoveFile_Hint=从工程中移除文件
aRemoveRedundantBlank_Caption=移除多余的空白行
aRemoveSpaces_Caption=移除多余空格...
aRemoveSpaces_Hint=移除文本中,文本前或文本后的空白对话框
aRemoveTags_Caption=移除 HTML 标签
aRemovetags_Hint=移除 HTML 标签并生成只有本文的新文件
aReOpen_Caption=重新打开活跃文件
aReOpen_Hint=重新打开活跃文件且放弃之前任何修改
aRepeatLastAction_Caption=重复上次执行的指令
aReplace_Caption=替换...
aReplace_Hint=替换成另一段文本
aResolveColor_Caption=色彩转换器...
aResolveColor_Hint=显示光标下代码的颜色
aRestoreLastClosedFile_Caption=恢复上个关闭的文件
aRightEdgeToCursor_Caption=设置“右边缘”为光标位置
aRollBar_Caption=标尺
aRTFImport_Caption=从 RTF 文件导入...
aSave_Caption=保存(&S)
aSave_Hint=保存文件
aSaveAll_Caption=全部保存(&L)
aSaveAll_Hint=保存所有打开文件的更改
aSaveAs_Caption=另存为(&A)...
aSaveAs_Hint=将打开的文件另存为新文件
aSaveAsPlugin_Caption=使用插件保存...
aSaveBlock_Caption=将区块另存为...
aSaveSameTime_Caption=保存时不更改文件日期
aSaveToFTP_Caption=保存到 FTP
aScriptsRecompile_Caption=重新编译脚本
aSelectAll_Caption=全选
aSelectAll_Hint=将所有文本标记为已选
aSelectNext_Caption=下一个窗口
aSelectNext_Hint=切换到下一个文件
aSelectPrew_Caption=上一个窗口
aSelectPrew_Hint=切换到上一个文件
aSelInsideMarks_Caption=选择书签内文本
aSelMatchBracket_caption=选择括号内的内容
aSelString_Caption=选择字符串
aSendToDisk_Caption=保存到磁盘驱动器A:
aSendToDisk_Hint=保存当前文件到磁盘驱动器 A:
aSentensize_Caption=句型化
aSessionManager_Caption=会话管理器...
aSessionSave_Caption=保存会话...
aSetMain_Caption=设置为编译程序的主文件
aSetMark_Caption=设置/删除书签
aShellOpen_Caption=用外部程序打开
aShellOpen_Hint=以外部程序打开当前文件
aShowControlBar_Caption=显示/隐藏工具栏
aShowOEM_Caption=显示 OEM 字符
aShowSpecChar_Caption=特殊字符
aShowSpecChar_Hint=显示/隐藏空格符、Tab 字符、行尾终止符
aSort_Caption=排序...
aSortFiles_Caption=依名称排序
aSpell_Caption=拼写检查
aSpell_Hint=拼写检查
aSpellCheck_Caption=拼写检查
aSpellSett_Caption=拼写检查设置...
aSplitLine_Caption=分割行
aSplitLine_Hint=分割当前行使用空格作为分隔符
aStayOnTop_Caption=最上层显示
aStayOnTop_Hint=总是显示在最上层
aSwapLineAbove_Caption=与上方行互换
aSwapLineBellow_Caption=与下方行互换
aSwapBlock_Caption=互换区块中的行
aSwitchLog_Caption=切换到编辑器/日志
aSyntax_Caption=语法
aSyntax_Hint=显示/隐藏语法
aSyntaxChange_Caption=更改语法...
aSyntaxChange_Hint=更改文档语法高亮
aSysEdit_Caption=打开系统文件
aSysEdit_Hint=系统文件编辑器:Autoexec.BAT, Config.SYS, System.INI, Win.INI
aTabColor_Caption=文件标签颜色...
aTabToSpaces_Caption=将标签转成空格...
aTabToSpaces_Hint=将所有标签转成空格
aTagToLowercase_Caption=标签转成小写
aTagToLowercase_Hint=将 HTML 标签转成小写
aTagToUpperCase_Caption=标签转成大写
aTagToUpperCase_Hint=将 HTML 标签转成大写
aTextToHTML_Caption=文本转成 HTML 格式
aToJScript_Caption=选取的文本转成 JavaScript
aToPHP_Caption=选取的文本转成 PHP 变量
aTopStyle_Hint=编辑 CSS 文件或 TopStyle 里所选文本
aUndo_Caption=撤消
aUndo_Hint=撤消上次更改
aUnfoldAll_Caption=展开全部
aUnfoldNearest_Caption=展开最近的
aUnfoldlevel1_Caption=展开第一层
aUnfoldlevel2_Caption=展开第二层
aUnfoldlevel3_Caption=展开第三层
aUnicodeNormComp_Caption=Canonical composition
aUnicodeNormDecomp_Caption=Canonical decomposition
aUnIndent_Caption=取消区块缩进
aUnIndent_Hint=减少区块缩进
aUnQuote_Caption=移除 E-mail 引用
aUnQuote_Hint=移除选取区块每一列开头的">"符号
aUpperCase_Caption=转成大写
aUpperCase_Hint=把字符转成大写
aUserConvertors_Caption=用户转换器...
aUserHL_Caption=用户语法高亮...
aVars_Caption=用户变量....
aWindCascade_Caption=层叠
aWindSplitHoriz_Caption=水平分割
aWindSplitVert_Caption=垂直分割
aWindTile_Caption=排列
aWindTileHoriz_Caption=水平并排
aWindTileVert_Caption=垂直并排
aWordWrap_Caption=文本自动换行
aWordWrap_Hint=打开/关闭自动换行功能
aWWW_Caption=PSPad 官方网站...
aWWW_Hint=访问 PSPad 官方网站
[Main Menu]
lSQLDialect_Caption=SQL 风格:
mActLine_Caption=当前行
mAllPanels_Caption=全部显示
mBlockCol_Caption=列选择
mBlockFormat_Caption=区块格式
mBlockKind_Caption=选择类型
mBlockLine_Caption=多行选择
mBlockNormal_Caption=正常选择
mCharCase_Caption=字符大小写转换
mCloseLeft_Caption=关闭左侧所有文件
mCloseNonActive_Caption=关闭除当前文件外的其他文件
mCloseRight_Caption=关闭右侧所有文件
mCompareWithTab_Caption=与当前分页进行文本比对
mControlPanel_Caption=控制
mCopyFileName_Caption=复制文件名到剪贴板
mCopyFullFileName_Caption=复制完整文件名到剪贴板
mCPAutoDetect_Caption=自动检测 CP
mCPConfigure_Caption=配置...
mEdit_Caption=编辑(&E)
mEditPanel_Caption=编辑
mEditTemplate_Caption=编辑模板定义文件
mEncoding_Caption=编码
mExport_Caption=导出
mFile_Caption=文件(&F)
mFind_Caption=搜索(&S)
mFormat_Caption=格式(&O)
mForum_Caption=PSPad 官方论坛...
mGotoBookMark_Caption=跳到书签(Alt+Up/Down)
mHelp_Caption=帮助(&x)
mHelpChanges_Caption=历史...
mHelpContents_Caption=帮助
mHelpFAQ_Caption=常见问题
mHelpOnline_Caption=在线帮助
mHTML_Caption=&HTML
mHTMLConv_Caption=转换
mHTMLPrev2_Caption=经由网页服务器预览 HTML
mInsertSpecial_Caption=特殊
mLineOperation_Caption=多行操作
mLockIt_Caption=同步移动
mLogCopyAll_Caption=复制全部
mMacro_Caption=宏
mMainPanel_Caption=主要
mMinimap_Caption=迷你地图
mNoPanels_Caption=全部隐藏
mNoSuggest_Caption=(无任何建议)
mOpenInExplorer_Caption=在资源管理器中打开”文件“文件夹
mOpenRecent_Caption=打开特殊/最近(%E)
mPanels_Caption=工具栏
mPHPCB_Caption=PHP - 代码美化器
mProject_Caption=工程(&J)
mProjNormOpen_Caption=在 PSPad 中打开
mProjPanel_Caption=工程(&P)
mProjShellOpen_Caption=用默认程序打开
mProjSysmenu_Caption=系统快捷菜单
mRename_Caption=重命名文件夹
mSaveWindowPos_Caption=保存主窗口位置
mScripts_Caption=脚本(&R)
mSessions_Caption=会话
mSetBookMark_Caption=建立书签(或 Alt+Left)
mSettings_Caption=设置(&N)
mShellOpen_Caption=在外部程序中打开
mSpecConvert_Caption=特殊转换
mTextDiff_Caption=文本差异
mTools_Caption=工具(&T)
mToolsOnline_Caption=在线工具
mTrayRestore_Caption=恢复上个状态
mTrayRestoreEmpty_Caption=恢复空白
mUnicodeNormalize_Caption=Unicode 正常化
mUserShortCut_Caption=文本片段热键
mView_Caption=查看(&V)
mViewPanel_Caption=查看
mWindow_Caption=窗口(&W)
mWWWVersion_Caption=检查 PSPad 是否有新版本...
tbFSCollapse_Hint=全部收起
tbFSExpand_Hint=全部展开
tbfsList_Hint=在新文件中打开结果
tbfsOpen_Hint=打开所有文件
tbFTPListLog_Hint=LIST 指令的结果
tbFTPMailLog_Hint=邮件发送 FTP 日志
tbLogFont1_Hint=日志窗口字体
tsFileFind_Caption=多重文件搜索结果
tsSearch_Caption=搜索结果
[General Strings]
rs_AddToProject=添加文件"%s"到工程?
rs_AktVersion=你的版本已是最新版:
rs_All=全部(&A)
rs_AllFiles=所有文件
rs_Apply=应用
rs_ASCIICPAsFile=CP 作为编辑器
rs_ASCIITable=ASCII 表
rs_ASCIITitleLine=ASCII 代码表 代码页 Windows ANSI 由 PSPad 打印
rs_Asterisk=信息
rs_AttribInfo=文件已设置属性:%s
rs_BadExpression=搜索表达式有误
rs_BlockConfirm=确定要对整份文档执行动作"%s"?
rs_Bookmark=书签
rs_Cancel=取消
rs_CannotOpenFile=无法打开文件 %s
rs_CannotOpenUTF8=文件 %s\n包含损坏的 UTF-8 编码。你想打开它吗?
rs_Center=置中
rs_Changed=已修改
rs_Char=字符
rs_ClipNoHTML=剪贴板并未含有 HTML 格式
rs_Close=关闭
rs_CloseAllFiles=关闭所有打开的文件吗?
rs_CloseAllquestion=确定关闭所有已打开的文件?
rs_CloseProject=关闭工程文件?
rs_CodeFolding=代码折叠
rs_CodePage=代码页:
rs_CompError=执行编译程序时发生错误。\n要更改编译程序设置吗?
rs_ConfirmCloseApp=你确定要关闭 PSPad 吗?
rs_ConfirmDelete=确定删除 "%s" 吗?
rs_ConfirmHexMode=这个文件看起来是个二进制文件。你想在十六进制编辑器中打开它吗?\n\n%s
rs_ContBegin=从文件开头继续搜索?
rs_ContEnd=从文件末尾继续搜索?
rs_CPLast=依「格式」选单的设置
rs_CPLat=OEM (DOS)
rs_CPWin=ANSI (Windows)
rs_DecodeError=无法解码此字符串
rs_DiffDifferentEncoding=你想比较的文件的编码不同。\n先在 PSPad 中打开这两个文件,然后选择对活跃标签页进行 TextDiff 功能。
rs_Dec=Dec
rs_Hex=Hex
rs_Uni=Uni
rs_Entity=条目
rs_Default=默认值
rs_DefaultKeys1=你确定要重设热键为默认值?
rs_DefaultKeys2=必须重新启动 PSPad 才能应用预设热键设置.
rs_DelAllMarks=确定要删除所有书签吗?
rs_DeleteHistory=确定删除最近使用过的文件历史及搜索记录?
rs_DictLoaded=字典:%s 单词数:%d
rs_DictLoading=正在加载 %s 字典...
rs_DictNotFound=找不到目录 "%s"
rs_Direction=方向
rs_DiskNotReady=磁盘驱动器尚未就绪
rs_Down=底部
rs_EnterWWW=输入要添加的网络链接地址:
rs_Error=错误
rs_Exclamation=注意
rs_ExportAs=导出为
rs_File=文件名
rs_FileExists=文件 "%s" 已存在。\n你确定要覆盖它吗?
rs_FileHint1=左键选取文件
rs_FileHint2=右键显示/隐藏第二个文件
rs_FileHint3=你可以用鼠标拖曳来更改页签顺序
rs_FileLocked=文件被另一用户锁定
rs_FileLockedUser=文件被此用户锁定:%s
rs_FileLockError=无法创建文件锁:
rs_FileName=文件名:
rs_FileNotFoundDeleted=文件内容更改检查 - 没找到文件!已经删除了吗?
rs_FileSizeWarn=你确定要打开这个大小 %d MB 的文件吗?
rs_FilesName=名称
rs_FilesSize=大小
rs_FilesModified=修改时间
rs_FilesType=类型
rs_FilesRights=权限
rs_FileWasChangedQuestion=文件内容已被修改,重新加载吗?
rs_FileWillBeExportAs=导出文件 %s 为 %s
rs_FillTemplateContents=文本片段内容不能为空
rs_FillTemplateHint=请填入片段描述
rs_FillTemplateName=请填入片段名称
rs_Find=查找(&I)
rs_Folder=文件夹
rs_FolderExists=文件夹"%s"已存在。请输入新名称。
rs_Found="%s" 出现了 %d 次
rs_FTPSaveErr=FTP 文件保存错误\n连接: %s\n文件: %s
rs_FullUndoImpossible=无法撤销所有替换, 因为撤消步骤不足
rs_GetUserParam=输入参数值:
rs_HotKeyExists=热键 %s 已指定给"%s"。覆盖吗?
rs_InetVersion=互联网上有新版本:
rs_Insert=插入
rs_LastOpenFileNotFound=无法定位上一程序会话中打开的文件
rs_LastUsed=上次使用
rs_LineNumber=行号:
rs_Lines=行
rs_Macro=宏
rs_MacroPlayError=运行命令时遇到问题:
rs_MacroPlayX=宏播放次数:
rs_MacroSave=输入宏名称:
rs_MailNotSend=发送 E-mail 时发生错误(需要有 SIMPLE MAPI 支持)。\n请检查程序设置互联网部分的 E-mail 客户端设置
rs_Modify=修改...
rs_MoreFiles=更多文件...
rs_MultiError=无法将多重语法着色器设置为它自身的组成部分!
rs_NeverShowAgain=不再显示
rs_NewDir=输入新的目录名称:
rs_NewFile=新建
rs_NewFileName=输入新文件名:
rs_NewVersionAvailable=有新的 PSPad 版本 %s 可用。\n你想要访问网页下载吗?
rs_No=否(&N)
rs_NoConnect=FTP:无法联机到 "%s"
rs_NoConnection=连接 "%s"并不存在
rs_NoExtHelp=尚未替 %s 文件指定外部帮助文件。\n请到「设置->语法高亮设置->规范」进行设置。
rs_NoFind=找不到下一个 "%s"。
rs_NoInternetConnect=无法连接网络。\n请检查「程序设置.../因特网」
rs_None=无
rs_NoToAll=全部否(&O)
rs_OK=确定(&O)
rs_OpenError=打开文件 "%s" 时出错
rs_Options=选项
rs_OverWrite=覆盖
rs_Page=页面:
rs_Password=密码:
rs_Path=路径
rs_Position=绝对位置:
rs_Programs=应用程序
rs_ProjDelFold=确定删除非空白的工程文件夹?
rs_ProjDirMising=未指定工程文件夹。你想打开工程设置吗?
rs_Project=新建工程
rs_ProjFile=未找到工程文件:\n"%s"\n你想指定文件位置吗?
rs_ProjNotSaved=工程 "%s" 已修改。保存工程吗?
rs_PSPadDownload=你想访问 PSPad 官方网站下载最新版本吗?
rs_PSPadHome=http://www.pspad.com/en/
rs_PSPadINIProj=无法添加 PSPad 的配置文件到工程
rs_Question=确认
rs_Rename=输入新的文件/目录名称:
rs_ReopenWarn=文件 "%s" 已更改。\n重新打开后,更改将丢失。继续吗?
rs_Repeat=重复(&R)
rs_Replace=替换(&R)
rs_replaced=搜索的表达式 "%s" 被替换了 %dx 次
rs_ReplaceStringQuestion=替换吗?
rs_ReplFilesQuestion=要把全部的 "%s" 替换成 "%s" 吗?
rs_Reserved=不能使用名称 "%s"。它是个保留词
rs_Result=结果:%f%s 复制结果到剪贴板?
rs_RowNumber=列:
rs_SaveError=保存文件 "%s" 时发生错误
rs_SaveFileChangesQuestion=保存对文件所做的修改吗?
rs_Scope=范围
rs_SessionName=输入会话名称:
rs_SuspiciousLine=在下列行中检测到可疑内容 (char #00) :
rs_Syntax=语法:
rs_SystemFolders=无法定位系统文件夹
rs_TabWidth=输入欲转换标签宽度:
rs_TaskComplete=此任务已经完成。
rs_Total=合计
rs_UndockCTRL=按下 CTRL 键并保持不动以解锁窗口
rs_UnsupportedFormat=文件 %s 的格式不受支持或已损坏。
rs_Up=Top
rs_UserName=用户名:
rs_UserParam=用户参数
rs_Value=值
rs_Variable=变量
rs_Warning=警告
rs_WebGetMoreInfo=打开 Web 浏览器查看更多信息吗?
rs_WinExec_BadCommandFormat=下达给外部应用程序的指令有误
rs_WinExec_BadFormat=此 .EXE 文件无效 (非 Win32 .EXE 或 .EXE image 出错)
rs_WinExec_ExecError=执行外部应用程序时发生错误
rs_WinExec_FileNotFound=找不到指定文件
rs_WinExec_NoResources=系统内存或资源不足
rs_WinExec_PathNotFound=找不到指定路径
rs_WWWAddress=网络链接
rs_Yes=是(&Y)
rs_YesToAll=全部是(&A)
[Find Replace]
bBookmarks_Caption=创建书签(&K)
bCopy_Caption=复制(&Y)
bCount_Caption=计数(&U)
bList_Caption=列表(&L)
bFindProfileDel_Caption=删除
bFindProfileLoad_Caption=加载
bFindprofileSave_Caption=保存
cAddLineNum_Caption=添加行号(&M)
cAskReplace_Caption=每次替换前均提示(&P)
cCaseSensitive_Caption=区分大小写(&V)
cCopyNonMatching_Caption=复制不匹配的
cRegExp_Caption=正规表达式(&R)
cWholeWord_Caption=全词匹配(&W)
lFindProfile_Caption=P&rofile:
rAllText_Caption=全局(&G)
rBackward_Caption=向上搜索(&B)
rEntireScope_Caption=整个文件(&E)
rForward_Caption=向下搜索(&F)
rSelectedText_Caption=所选文本(&S)
[About dialog]
FormCaption=关于 PSPad
lAdress_Caption=地址:
lAuthor_Caption=作者:
lPSPadVer_Caption=程序版本:
[Print Preview]
aColorPrint_Caption=彩色打印
aWrapLines_Caption=换行打印
bExit_Hint=退出预览
FirstCmd_Hint=第一页
Fitto_Caption=适合整页
LastCmd_Hint=最后一页
NextCmd_Hint=下一页
OriginalSize_Caption=100%
PageWidth_Caption=页宽
PrevCmd_Hint=上一页
ZoomCmd_Hint=缩放
[Template]
FormCaption=新文本片段
lCursPos_Caption=| - 脱字符位置(ASCII %s)
lHotKey_Caption=快捷方式:
lSelCont_Caption=%s- 插入所选文本(ASCII %s)
lTemplateContents_Caption=片段内容
lTemplateDescr_Caption=片段描述
lTemplateName_Caption=片段名称
[Settings]
aAddItem_Caption=添加新项(&A)
aDelItem_Caption=删除(&D)
aEditItem_Caption=替换(&R)
bBlockColor_Caption=选取区块背景颜色
bBlockFont_Caption=选取区块字体颜色
bBlockOccur_Caption=Occurrences Back
bBracket_Caption=括号
bClearHistory_Caption=清除历史纪录
bConfigBackup_Caption=备份配置...
bConfigBackup_Hint=备份 PSPad 配置到选定文件
bConfigRestore_Caption=还原配置...
bConfigRestore_Hint=从所选文件还原 PSPad 配置
bCurrentTab_Caption=当前标签页
bDiffAdd_Caption=已添加
bDiffDel_Caption=已删除
bDiffMod_Caption=已修改
bDownloadDic_Caption=从网络下载字典文件...
bEdit_Caption=直接编辑(&E)
bEdit_Hint=直接编辑 PSPad.ini 文件
bGutterBack_Caption=边条
bGutterFont_Caption=边条字体颜色
bKeyClear_Caption=清除全部
bKeyMapLoad_Caption=由文件载入...
bKeyMapSave_Caption=保存到文件...
bKeyReset_Caption=撤销更改
bLinkColor_Caption=超链接颜色
bLogParser_Caption=日志解析器
bRegAll_Caption=注册全部
bRegNone_Caption=取消全部注册
bReloadDic_Caption=重新载入字典
bSpell_Caption=拼写检查
bUpdateCheckNow_Caption=立即检查...
bVisitedLinkColor_Caption=已访问过的超链接
cActiveDir_Caption=与当前文档相同
cActiveDir_Hint=将“打开对话框目录”设置为当前文档的目录
cAddCrLf_Caption=在文件尾自动补上 CR+LF
cAddCrLf_Hint=确保文件尾有一空白列
cAllFile_Caption=整合到系统右键菜单
cAllFile_Hint=将 PSPad 加到系统右键菜单-你能打开任何文件
cALTColumn_Caption=按 ALT 键设置列模式
cALTColumn_Hint=Alt 键加鼠标设置列选择模式
cAlwaysThisType_Caption=始终使用这个文件类型
cAppAnalytics_Caption=匿名应用程序使用情况跟踪
cAutoBrackets_Caption=自动补齐这些字符 ( { [ < " '
cAutoBrackets_Hint=当你输入开始字符, 编辑器自动补上匹配的终止符
cAutoCompleteBracket_Caption=自动完成包括第一个括号
cAutoCompleteConfirm_Caption=用空格和符号确认自动完成
cAutoCompleteConfirm_Hint=提供的自动完成项目通过空格和符号,如括号、分号、冒号等进行确认… ...
cAutocompletetrimWord_Caption=自动补全替换单词的其余部分
cAutoCorrActive_Caption=启用
cAutoCorrCharCase_Caption=保持字符大小写
cAutoHideGutter_Caption=自动隐藏左侧边条
cAutoHideGutter_Hint=如果没有书签或可见的行号就自动隐藏左侧边条
cAutoIndent_Caption=自动缩进模式
cAutoIndent_Hint=根据上一行自动缩进
cAutoSaveExit_Caption=程序退出时自动保存文件(包括新文件)
cAutoSaveLostFocus_Caption=失去焦点时自动保存文件(新文件除外)
cAutoSavePos_Caption=自动保存主窗口位置
cAutoSaveSuspExist_Caption=现有的(已保存的)文件
cAutoSaveSuspNew_Caption=新的(未保存的)文件
cbCursInsert_Caption="区块","半区块","水平线","垂直线"
cbFileBar_Text=始终可见\n从不可见\n对两个及以上文件可见
cbFileBarStyle_Text=标签\n按钮\n平坦按钮
cBold_Caption=粗体(&B)
cbSaveWork_Text=不要恢复文件\n只恢复由 PSPad 所打开的\n所有打开的文件
cbStartFile_Text=显示「打开新文件」对话框\n打开预设的空白文件\n不要打开文件
cbStyle_Hint=程序样式主题
cbTabSwitch_Text=标准切换方式\n最后两份文件\n最后使用的顺序
cCloseAllDlg_Caption=全部关闭前显示确认对话框
cCloseAppDlg_Caption=关闭 PSPad 前显示确认对话框(若有打开文件)
cCloseMinimize_Caption=仅在关闭时最小化
cCloseMinimize_Hint=PSPad 只在被关闭时最小化
cCodeExplorerRefreshSave_Caption=文件保存后刷新代码资源管理器内容
cCodeFoldSupport_Caption=代码折叠支持
cCodeFoldGuides_Caption=代码缩进指南
cCodeFoldHints_Caption=折叠行提示标记
cColorPrint_Caption=彩色打印语法高亮颜色
cColorPrint_Hint=打印时印出语法高亮颜色
cCSSAddEOL_Caption=CSS-各部分以空白行隔开
cCSSColorRGB_Caption=CSS-插入 RGB(r,g,b)格式的色码
cCSSColorRGB_Hint=CSS-插入 RGB(r,g,b)格式的色码而不是标准的#rrggbb
cCursorEdge_Caption=在光标位置上显示垂直线
cCycleMarks_Caption=循环显示书签
cCzechOEM_Caption=捷克语 ANSI<--> OEM 转换
cCzechOEM_Hint=用内置 ANSI<-->OEM 转换,捷克语专用!
cDelMarksDlg_Caption=删除所有书签前显示确认对话框
cDesignateDir_Caption=指定目录:
cDesignateDir_Hint=“打开文件”对话框使用这个目录
cDiffAutoSave_Caption=在工具调用之前保存文件
cDiffBlanks_Caption=忽略空白区
cDiffBlanks_Hint=比较文本差异时忽略空白
cDiffCharCase_Caption=忽略字符大小写
cDiffCharCase_Hint=比较文本差异时忽略字符大小写
cDiffExtTool_Caption=使用外部差异比较工具
cDiffNoHl_Caption=忽略高亮度颜色
cDiffNoHL_Hint=比较文本差异时不使用高亮显示
cEmailDefault_Caption=使用默认 E-mail 客户端
cExitEsc_Caption=按 ESC 退出程序
cExitEsc_Hint=按 ESC 键退出程序
cExtEdit_Caption=增强的剪切和复制功能
cExtEdit_Hint=如果没选择文本, 就剪切和复制当前行
cExtEnd_Caption=增强 End 键
cExtEnd_Hint=第一次将光标移到最后一个字符的后面,第二次移到行尾
cExtHome_Caption=增强 Home 键
cExtHome_Hint=第一次将光标移到第一个单词的开头,第二次移动光标到行开头
cFileBarTop_Caption=分页标签置于上方
cFileBarTop_Hint=分页标签的位置 (顶部/底部)
cFileIcons_Caption=在文件浏览器里显示系统图标
cFindFilesKeepReplace_Caption=在多文件中搜索-记住替换设置
cFindFilesKeepReplace_Hint=对话框搜索/替换文件-PSpad 会话期间记住替换复选框和字段设置
cFindFillUpFind_Caption=搜索-将选取的或当前的文本填入搜索字段
cFindFillUpFind_Hint=搜索对话框-将选取的或当前的单词填入搜索字段
cFindFillUpReplace_Caption=替换-将剪贴板的内容填入替换字段
cFindFillUpReplace_Hint=搜索对话框-自动将剪贴板的内容填入替换字段
cForceFirstMonitor_Caption=强制恢复到主显示屏
cForceFirstMonitor_Hint=启动后,PSPad将恢复在第一个屏幕上
cFTPOverWriteDlg_Caption=透过 FTP 覆盖既有文件前显示确认对话框
cGroupUndo_Caption=群组撤消操作
cHexInContextMenu_Caption=添加 PSPad 十六进制选单到系统快捷菜单
cHideExt_Caption=分页标签不显示文件扩展名
cHideExt_Hint=分页标签显示文件名而不显示扩展名
cHTMLMulti_Caption=启动 HTML 多重语法高亮
cHTMLMulti_Hint=在 HTML 代码中显示高亮脚本
cHTMLViewer_Caption=在 IE 中注册为 HTML 查看器
cIconFollowsMonitor_Caption=程序图标跟随显示器 - 限制额外信息
cIconFollowsMonitor_Hint=启用后,当 PSPad 移动到另一个监视器时,程序图标将跟随。它将不允许在任务栏上显示自定义图标名称。
cIEBrowser_Caption=设为 IE5 + 的 HTML 查看器
cIEBrowser_Hint=设为 IE 的 HTML 源码查看器
cIEEditor_Caption=设为 IE 的 HTML 编辑器
cIEEditor_Hint=设为 IE 的主 HTML 编辑器
cItalic_Caption=斜体(&I)
cKeepToolbarIconSize_Caption=显示器 DPI 改变时,不要改变工具栏图标的大小
cLnkDesktop_Caption=在桌面建立快捷方式
cLnkDesktop_Hint=在屏幕上创建 PSPad 快捷方式
cLnkSendTo_Caption=建立快捷方式到系统快捷菜单的「发送到」菜单
cLnkSendTo_Hint=添加 PSPad 快捷方式到系统快捷菜单的「发送到」选单
cLnkStart_Caption=在开始选单建立快捷方式
cLnkStart_Hint=在开始选单生成 PSPad 快捷方式
cLocalFilesOnly_Caption=只保存本地驱动器的文件
cLocalFilesOnly_Hint=只从本地驱动器保存工作和最近的文件
cLogToEnd_Caption=在日志中跟踪编译进度(更慢)
cLogToEnd_Hint=在“日志”窗口中,您将看到编译过程中的编译进度
cMiddleMouse_Caption=鼠标中键-片段列表
cMiddleMouse_Hint=按鼠标中键显示片段列表
cMouseButtonEx_Caption=使用扩展的鼠标按钮
cMultiFile_Caption=只允许一个 PSPad 实例
cMultiFile_Hint=同一时间只允许执行一个 PSPad 实例
cMultiFileBar_Caption=分页标签-允许多行选项卡
cMultiFileBar_Hint=多行分页标签
cMultimediaKeys_Caption=启用多媒体键盘的扩展按键
cMultiUser_Caption=多用户环境
cMultiUser_Hint=保存配置到用户配置文件夹
cOperaBrowser_Caption=Opera 的 HTML 查看器
cOperaBrowser_Hint=将 PSPad 设为 Opera 浏览器的 HTML 源码查看器
cProjAutoSort_Caption=工程-自动按字母顺序对文件进行排序
cProjAutoSort_Hint=按字母顺序自动排序工程内的文件
cProjCloseFiles_Caption=先关闭当前文件再打开新工程
cProjHints_Caption=工程-包含路径的文件名
cProjHints_Hint=在工程树状列表显示完整文件名作为提示
cProxyAsIE_Caption=从系统 Internet 设置中获取代理服务器设置
cProxyUse_Caption=使用代理服务器
cProxyUse_Hint=使用代理服务器联网
cRealTabs_Caption=真标签
cRealTabs_Hint=在文本中使用真标签(09h)
cRecentFiles_Caption=保存最近项目
cRecentFiles_Hint=保存打开文件历史、搜索历史等 ...
cRememberDir_Caption=记住上次使用的目录
cRememberDir_Hint=记住上次使用的文件打开目录
cRememberFilter_Caption=记住上次的筛选器
cRememberFilter_Hint=记得上次使用的文件打开筛选器
cRMouseNotMove_Caption=右键单击时不移动光标
cRMouseNotMove_Hint=按鼠标右键时不更改光标位置
cROAttribut_Caption=只读模式更改文件属性
cROAttribut_Hint=在 PSPad 中的只读状态设置只读文件属性
cSaveFileState_Caption=记住文件之状态
cSaveFileState_Hint=记住文件的状态以便日后打开
cScrollPastEOF_Caption=Scroll past EOF
cScrollPastEOF_Hint=Scroll past end of file
cScrollPastEOL_Caption=Scroll past EOL
cScrollPastEOL_Hint=Scroll past end of line
cSearchAgainDlg_Caption=若没有找到文本,询问是否要从头/尾再次搜索
cSearchFileDlg_Caption=在文件内查找-总计
cSelectOccur_Caption=突出显示所选文本所有出现的地方
cSelectOccurSensitive_Caption=高亮出现区分大小写
cShellHexEdit_Caption=显示条目:PSPad 十六进制
cShellSubmenu_Caption=层叠式快捷菜单
cShellTextDiff_Caption=显示条目:PSPad 文本差异比较
cShowBrackets_Caption=突出显示相匹配的括号
cShowBrackets_Hint=在光标下方突出显示匹配的括号
cShowHiddenFiles_Caption=在文件浏览器里显示系统文件及隐藏文件
cShowMenuPic_Caption=在菜单中显示图标
cShowSplash_Caption=启动时显示程序欢迎画面
cShowSplash_Hint=程序启动时显示欢迎画面
cSmartAutoBrackets_Caption=智能型字符自动补齐
cSmartAutoBrackets_Hint=如果字符已经存在就不要补齐
cSmartTabs_Caption=智能标签
cSmartTabs_Hint=标签宽度取决于前一行
cSortCodeExplorer_Caption=程序代码浏览器结果依字母排序
cSpellNo1Char_Caption=忽略只有一个字符的单词
cSpellNoNumber_Caption=忽略有数字的单词
cSplitHorizont_Caption=水平分割窗口以便同步处理文件
cSplitHorizont_Hint=同步时默认的窗口分割模式
cStatusClick_Caption=双击状态栏执行特定功能(取消勾选则是单击执行)
cTabDblClick_Caption=分页标签-鼠标双击关闭文件
cTabInCSS_Caption=重定 CSS 格式时使用真标签
cTabInCSS_Hint=重定 CSS 格式将使用真标签来缩进
cTemplSort_Caption=代码剪辑(Clip)-排序交互式剪辑变量
cTemplSort_Hint=依据字母变量顺序排序交互式剪辑
cTextHTMLLine_Caption=HTML -文本转成 HTML -把行视为段落
cTextHTMLLine_Hint=文本转成 HTML 将把行标记为段落
cTrayEnabled_Caption=关闭程序时缩小到托盘区图标
cTrayEnabled_Hint=关闭程序时缩小 PSPad 到托盘区,而不是关闭程序
cTrimSpaces_Caption=移除结尾的空格
cTrimSpaces_Hint=移去行尾的空格
cTXTFile_Caption=打开 TXT 文件(&T)
cTXTFile_Hint=改用 PSPad 而不是 Notepad 打开 TXT 文件
cUnderLine_Caption=下划线(&U)
cUpdateCheck_Caption=检查程序更新
cUpdateCheckDevel_Caption=检查包括开发者版本
cURLHighlight_Caption=若未指定语法高亮,则高亮显示 URL 地址
cUseHLColor_Caption=选取颜色与高亮程序相同
cUseHLColor_Hint=脚本开头和结尾将使用该脚本的属性颜色进行高亮
cUTFHeader_Caption=识别 UTF-8 编码的 . 字节
cUTFHeader_Hint=将 BOM(字节顺序标记)写入 UTF-8 编码文件
cWholeNextWord_Caption=Whole Words for Find Word at Cursor
cWholeNextWord_Hint=Set "whole words only" option with search word under cursor
cWrapWithEdge_Caption=到达右边界时换行
cWrapWithEdge_Hint=将在右边缘标记处动态换行
cWSHScripting_Caption=支持集成脚本功能(需事先安装 WSH)
eFileTab_Hint=%n%- 文件编号, %name%-文件名, %d:nn-最大文件名长度 (本参数必须放在最后)
eRightBorder_Hint=右边界符号位置
gbCVSImport_Caption=导入 CSV
gbFileLock_Caption=文件锁定
gbMultiBase_Caption=多重高亮基准:
gbMultiOpen_Caption=以多重语法高亮打开:
gbRecent_Caption=最近文件
gbRegistr_Caption=已注册文件类型:
gbRightEdge_Caption=右边界
lAdminRights_Caption=管理员权限
lAttrBackColor_Caption=背景颜色
lAttrFontColor_Caption=字体颜色
lAutoCompleteDelay_Caption=自动完成延迟 [毫秒]:
eAutoCompleteDelay_Hint=自动完成延迟。输入 0 禁用功能。
lAutoRefresh_Caption=自动更新[秒]:
lAutoReplace_Caption=表达式:
lAutoSave_Caption=自动保存[分]:
lAutoSaveSuspend_Caption=暂停多少时间后自动保存:
lAutoWith_Caption=替换为:
lBackColor_Caption=背景颜色
lBackUpBak_Caption=在文件名结尾加上 .BAK(file.ext.BAK)
lBackupBak2_Caption=在文件名结尾加上 .BAK(file.BAK.ext)
lbackUpDir_Caption=用于文件备份的文件夹:
lBackupFTP_Caption=FTP 文件的备份文件夹(留空使用 TEMP 文件夹):
lBackupNone_Caption=不要建立备份文件
lBackUpStyle_Caption=备份方法:
lBackUpTilde_Caption=扩展名前加上~符号(file.~ext)
lCSVDelim_Caption=分隔符:
lCSVEnclose_Caption=封口符号:
lCurLine_Caption=当前行
lCursInsert_Caption=插入模式光标样式:
lCursOver_Caption=覆写模式光标样式:
lDefaultCP_Caption=文件打开预设代码页:
lDiffPath_Caption=外部差异比较工具路径:
lDiffParams_Caption=差异比较工具参数:
lEdgePos_Caption=右边界位置:
leMail_Caption=E-mail:
lFileBar_Caption=分页标签可见性:
lFileBarStyle_Caption=分页标签样式:
lFileLocking_Caption=先关闭所有打开的文件
lFileSizeWarn_Caption=打开大小超过多少 [MB] 的文件时先进行确认:
lFilesToIgnore_Caption=要忽略的文件(过滤条件用分号隔开):
lFileTab_Caption=分页标签的标题格式:
lForeColor_Caption=字体颜色
lGotoTarget_Caption=搜索结果:
lHTDocs_Caption=文档根:
lHTMLCompLen_Caption=HTML - 压缩的行长度:
lHTServer_Caption=服务器:
lIDEStyle_Caption=PSPad IDE 样式:
lIDEStyle_Hint=设置 PSPad 皮肤
lIconSet_Caption=工具栏图标集:
lIndentWidth_Caption=缩进宽度:
lInternalIEVersion_Caption=内部 HTML 浏览器模式 (重启 PSPad):
lLineIndicatorWidth_Caption=更改的行指示符宽度:
lMaxLineLen_Caption=最大行长
lMaxUndo_Caption=可撤消次数的最大值:
lMenuIconSet_Caption=菜单按钮集:
lMouseScrollBy_Caption=鼠标滚轮滚动行数:
lMultiASP_Caption=用于 <%...%>:
lNew_Caption=新默认值:
lNewShortCut_Caption=新的快捷键:
lOldShortCut_Caption=旧的快捷键:
lProxyAdr_Caption=地址:
lProxyName_Caption=用户名:
lProxyPass_Caption=密码:
lProxyPort_Caption=端口:
lRegTyp_Caption=类型:
lSaveWork_Caption=保存工作环境/桌面:
lSpellDict_Caption=选择字典:
lSpellStyle_Caption=显示风格:
lStartFile_Caption=启动之后清空文件:
lTabSwitch_Caption=分页切换方式:
lTabWidth_Caption=分页宽度:
lUpdateInterval_Caption=每隔多少天检查程序更新:
lUpdateLastCheck_Caption=上次更新检查:
lWriteToDir_Caption=写入 PSPad 文件夹
rFileLockNone_Caption=打开时不要锁定文件
rFileLockAttr_Caption=用 R/O 属性锁定文件
rFileLockSmart_Caption=Smart file locking with LCK file
rs_tabAssociate=已注册的文件类型
rs_tabBackup=备份
rs_tabColors=颜色
rs_tabDialogs=确认
rs_tabEditBehaviour=编辑器(第一部分)
rs_tabEditSettings=编辑器(第二部分)
rs_tabEditFolding=代码折叠
rs_tabFiles=文件和目录
rs_tabHexSetting=十六进制编辑器
rs_tabHTMLTool=工具
rs_tabInternet=互联网
rs_tabKeyMap=热键映射
rs_tabLanguage=语言
rs_tabMultiHL=多重语法高亮
rs_tabProgBehaviour=程序(第二部分)
rs_tabProgLook=程序(第一部分)
rs_tabSystem=系统集成
rs_tabTextDiff=文件差异
rs_tabUpdates=更新
rs_tabWebServer=网络服务器
shBlockColor_Hint=所选区块的背景色
shBlockFont_Hint=所选区块的字体颜色
shBracket_Hint=突出显示的括号的部分背景
shCurLine_Hint=当前行的背景色
shDiffAdd_Hint=添加行的背景色
shDiffDel_Hint=缺失行的背景色
shDiffMod_Hint=修改行的背景色
shGutterBack_Hint=左侧边条的背景色
shGutterFont_Hint=左侧边条字体的颜色
shLinkColor_Hint=URL 链接颜色
shLOGparser_Hint=日志分析器结果的背景
shMainBackColor_Hint=通用背景色
shMainForeColor_Hint=通用字型颜色
shMultiBack_Hint=多重语法高亮部分开头和结尾的背景色
shMultiFore_Hint=多重语法高亮部分开头和结尾的字体颜色
shRightEdgeColor_Hint=右边界行的颜色
shSpell_Hint=给有问题的拼写加下划线
shVisitedLinkColor_Hint=已访问 URL 链接的颜色
rShellDLL_Caption=DLL 函数库(建议的)
rShellDLL_Hint=用 DLL 右键菜单处理程序将 PSpad 整合到 Windows 资源管理器
rShellRegistry_Caption=注册
rShellRegistry_Hint=用注册表将 PSpad 整合到 Windows 资源管理器
TabAutoCorrect_Caption=自动修正
[HTML color dialog]
r16Color_Caption=16 色调色盘
rGrayColor_Caption=灰阶
rNamed_Caption=已命名的颜色
rSafeColor_Caption=网页安全色
[Sort dialog]
bSortProfileDel_Caption=删除
bSortProfileLoad_Caption=加载
bSortprofileSave_Caption=保存
cASCII_Caption=ASCII 值
cCharCaseDiff_Caption=区分大小写
cColumn_Caption=指明列
cRemDuplic_Caption=删除重复
gbAdvanced_Caption=高级设置
gbDirection_Caption=方向
gbSortBy_Caption=排序方式
lColBegin_Caption=开始行号
lColLength_Caption=字符计数:
lSortProfile_Caption=配置文件(&R):
rANSI_Caption=ANSI 值
rAscending_Caption=升序
rDescending_Caption=降序
rLineLength_Caption=行长度
rNumber_Caption=数值
rReverse_Caption=将字符串反向
rUnicode_Caption=所选区域语言(十六进制)
[Page setup dialog]
cHeaderShadow_Caption=标题阴影
cMirrorMargin_Caption=对称页边距
cPrintHeader_Caption=打印标题
[Remove Spaces dialog]
cBegin_Caption=从行首
cEnd_Caption=从行尾
cInside_Caption=文本内
[DateTime dialog]
bAdd_Caption=添加(&A)
bDelete_Caption=删除(&D)
bReplace_Caption=替换(&R)
lDate_Caption=日期:
lTime_Caption=时间:
[Find in files]
aOpenDirectory_Hint=选择目录
cCaseSensitive_Caption=区分大小写(&C)
cClearResults_Caption=清除前次搜索结果(&L)
cCloseDialog_Caption=搜索后关闭对话框(&O)
cReplaceRO_Caption=替换 R/O 文件
cReplaceText_Caption=替换成(&R):
cSubdirectories_Caption=包括子目录(&I)
cWholeWord_Caption=只匹配整词(&W)
gbFindScope_Caption=搜索范围
lCodePage_Caption=文件代码页(&E):
lSearchMasks_Caption=文件掩码(&F):
lSearchText_Caption=要搜索的文本(&T):
rDirectoryFiles_Caption=选择的目录(&D):
rOpenFiles_Caption=打开文件(&N)
rProjectFiles_Caption=工程文件(&P)
rs_FilesResult=%d 次出现了 "%s",于 %d 个文件中,共搜索了 %d 个文件
[User Highlighter]
bLoad_Caption=载入(&L)...
bSave_Caption=保存(&S)
cCaseSensitive_Caption=单词区分大小写
cEscString_Caption=转义字符串
cKW1StartWith_Caption=关键词开头...
cLabel_Caption=标签
cPHPVariable_Caption=PHP 样式变量
cPreprocessors_Caption=预处理器
cRubySymbols_Caption=Ruby 符号
cVectors_Caption=矢量 ( v' )
cVectors_Hint=矢量支持,如 MathLab
eLineComment_Hint=用在添加/移除批注
FormCaption=自定义语法高亮
gbComment_Caption=批注样式
lCodeExplorerType_Caption=程序代码浏览器要应用的文件类型:
lCodeFoldingType_Caption=代码折叠类型:
lDocComment_Caption=文档注解:
lDocComment_Hint=代码资源管理器的标记注释的表达式。这个表达式后面的任何文本都被认为是文档注释
lGeneralName_Caption=名称:
lKeyWordChars_Caption=关键词中允许的字符串:
lLineComment_Caption=批注:
lMasks_Caption=文件类型,用逗号隔开
rApostropheQuote_Caption=反省略符
rDoubleQuote_Caption=双引号
rSingleQuote_Caption=单引号
[Highlighters settings]
bAdd_Caption=添加(&A)
bCobolFree_Caption=自由形式
bCobolStrict_Caption=固定形式
bDebug_Caption=调试...
bDel_Caption=删除(&D)
bEdit_Caption=替换(&R)
bFileTab_Caption=文件标签颜色
bHLBack_Caption=高亮器背景色
bModifyUserHL_Caption=修改高亮器
cAbsolutePath_Caption=文件绝对路径
cAbsolutePath_Hint=将以绝对路径存储文件,而非相对于工程文件的路径
cCompCapture_Caption=撷取程序的输出窗口
cCompOnBackground_Caption=后台编译
cCompOnBackground_Hint=编译将在后台运行
cCompHideOutp_Caption=隐藏输出窗口
cCompHideOutp_Hint=隐藏外部程序输出窗口
cCompSaveAll_Caption=编译前保存所有文件
cCPPPreprocStyle_Caption=备选预处理器风格
cCurrentLine_Caption=当前行
cDontOpen_Caption=载入工程后不打开任何文件
cDontOpen_Hint=只载入工程树列表,不打开任何文件
cHLRealTab_Caption=真实标签
cHTMLTemplate_Caption=Smarty 和 Django 模板支持
cProgSaveAll_Caption=在外部应用程序启动之前保存所有文件
cProgRunSelection_Caption=只在外部应用程序中运行选定的文本
cProjectFilesOnly_Caption=不要保存额外信息
cProjectFilesOnly_Hint=工程文件将包含来自工程的文件,但没有任何额外的信息,如书签,文件位置等。
eDocComment_Hint=用于代码管理器的文档注释识别字符串
FormCaption=高亮器设置
lCobolAreaA_Caption=区域 A 开始于:
lCobolAreaB_Caption=区域 B 开始于:
lCobolEndCode_Caption=代码结尾:
lCompDir_Caption=默认目录:
lCompFile_Caption=编译程序:
lCompLog_Caption=日志文件:
lCompLogEnc_Caption=日志编码:
lCompLogType_Caption=日志窗口类型:
lCompParam_Caption=参数:
lCompParser_Caption=日志解析器:
lCompRun_Caption=编译之后执行:
lExtension_Caption=文件掩码:
lHelpFile_Caption=帮助文件/URL 地址:
lIndentChars_Caption=扩展的缩进字符:
lLangName_Caption=筛选器名称:
lNewFileFormat_Caption=新的文件格式:
lProgFile_Caption=应用程序:
lProgList_Caption=应用程序列表:
lProgName_Caption=名称:
lProjectDir_Caption=工程默认目录:
lProjectExt_Caption=同步带扩展名的文件:
lRightEdge_Caption=右边界:
lScheme_Caption=配色方案:
lTabWidth_Caption=标签宽度:
lUserHL_Caption=用户高亮器:
rs_CommandLine=命令行:
TabColor_Caption=颜色(&C)
TabCompil_Caption=编译程序(&O)
TabExtension_Caption=规范(&S)
TabExtProgs_Caption=外部应用程序(&E)
TabGeneral_Caption=常规
[FindHex dialog]
cFindAsText_Caption=查找文本
cIgnoreCase_Caption=忽略字符大小写
lFindText_Caption=查找:
[GotoHex dialog]
lBytes_Caption=字节(&Y):
rFromBegin_Caption=从文件开头开始(&F)
rFromCurrent_Caption=由光标处开始(&R)
[Code Explorer]
aActivateSource=跳转后将焦点设置为来源
aCopyPath=复制节点路径到剪贴板
aCollapseNode=收起子节点
aExpandNode=展开子节点
aExportContent=将程序代码浏览器内容打开为新文件
aInsertInto=插入到编辑器
aRefresh=更新
aSortAZ=升序排序
aSortZA=降序排序
aSynchronize=与编辑器同步
lNotImplemented_Caption=未对该文件类型实现
[Spell check]
bSpellAddWord_Caption=添加到字典(&A)
bSpellChange_Caption=更改(&H)
bSpellChangeAdd_Caption=更改 + 添加(&N)
bSpellSkip_Caption=跳过(&S)
bSpellSkipAll_Caption=全部跳过(&K)
[Mail form]
rs_ErrDesc1=请在此用英文简短描述你遇到的错误,缺乏描述的 LOG 文件没有用处,我将忽略这样的邮件。
rs_ErrDesc2=如何重现错误:
rs_ErrDesc3=(如果错误发生在特定文件, 请把它作为附件一起发送)
[Calculate block]
lAvg_Caption=平均:
lCnt_Caption=计数:
lMax_Caption=最大值:
lMin_Caption=最小值:
lSum_Caption=总和:
[Macro Manager]
bEdit_Caption=编辑(&E)...
bPlay_Caption=播放(&P)
bPlayX_Caption=播放次数(&X)
lHotKey_Caption=指定快捷键:
[Statistics]
bRunStat_Caption=详细统计数字:
lFileName_Caption=文件名:
lFullName_Caption=完整文件名:
mCopyWords_Caption=复制单词表
rs_Chars=字符
rs_CharsCount=字符计数
rs_Created=建立时间
rs_FileSize=文件大小
rs_Frequency=频率
rs_LastWrite=上次修改时间
rs_LinesCount=行数
rs_MaxLength=行最大长度
rs_ThisVersion=这个版本
rs_Words=单词
rs_WordsCount=单词计数
[Show color]
cLockTracks_Caption=锁定
lColorCode_Caption=HTML 颜色代码:
lColorItems_Caption=R,G,B表示法:
lColorName_Caption=颜色名称:
lColorPercent_Caption=百分比表示法:
[Insert text]
cSkipEmpty_Caption=跳过空白行
cSkipWhiteSpace_Caption=跳过开头的空白
cTextToPos_Caption=从第几个字符开始插入:
lBeginText_Caption=在行开头:
lEndText_Caption=在行末尾:
lNumStart_Caption=Start:
lNumStep_Caption=Step:
lNumNum_Caption=Numbers:
rNumber_Caption=编号
rPoint_Caption=项目符号
rText_Caption=文本
[Google search]
gbAdvanced_Caption=高级搜索...
gbSimple_Caption=简易搜索
lAllWords_Caption=包含全部的字词(&A):
lAnyWords_Caption=包含任何一个字词(&N):
lEngine_Caption=使用特定国家或地区域名的谷歌搜索:
lExactPhrase_Caption=包含精确短语(&E):
lExpression_Caption=表示式(&E):
lLangResult_Caption=只显示下列语言的结果:
lNoWords_Caption=不包含指定字词(&X):
lResultCount_Caption=每一页搜索结果数(&R):
lServer_Caption=只在这个网域搜索(&S):
[CPCustomize]
aDown_Caption=将当前项目移到下面
aTop_Caption=将选中的项目重新排列到顶部
aUp_Caption=将当前项目移到上面
fCPCustomize_Caption=编码菜单自定义
rs_Code=代码
rs_Name=编码名称
rs_WebCode=HTML 代码
rs_Autodetect=自动检测
[FTP]
bFTPConnect_Caption=联机...
bFTPCopy_Caption=复制站点
bFTPDelete_Caption=删除
bFTPEdit_Caption=编辑...
bFTPFolder_Caption=新文件夹...
bFTPImport_Caption=导入(&I)
bFTPNew_Caption=新建连接...
cBinaryMode_Caption=二进制传输模式(类型I)
cFTPCutExtension_Caption=删除文件扩展名再保存到 FTP
cFTPHiddenFiles_Caption=显示隐藏文件(需 FTP 服务器支持)
cFTPKeep_Caption=发送下列命令保持连接状态:
cFTPKeepRandom_Caption=使用随机命令
cFTPLowerName_Caption=更改文件名为小写
cFTPOldList_Caption=旧式文件列举 (LIST,而非 MLSD)
cFTPOldPort_Caption=兼容模式 (用于旧式代理/NAT)
cFTPPassive_Caption=被动模式
cFTPProxy_Caption=使用代理服务器
cFTPSSL_Caption=使用 SSL/TLS,如果可用
cFTPSSLProtP_Caption=对 SSL,使用 Prot P (私密),而非 Prot C (明文) 模式
cOwnerExec_Caption=执行
cOwnerRead_Caption=读取
cOwnerWrite_Caption=写入
gbGroup_Caption=群组
gbOther_Caption=其他
gbOwner_Caption=拥有者
lFTPAccount_Caption=验证账号:
lFTPChangeDir_Caption=更改文件夹:
lFTPDir_Caption=远程目录:
lFTPFolder_Caption=添加到文件夹:
lFTPName_Caption=连接名称:
lFTPPassw_Caption=密码:
lFTPQuickSearch_Caption=快速搜索:
lFTPServer_Caption=服务器:
lFTPSSLDownload_Caption=下载 SSL/TLS 联机所需的组件
lFTPTime_Caption=每隔:
lFTPTimeOut_Caption=连接超时:
lFTPType_Caption=FTP 协议:
lFTPUser_Caption=用户名:
lMonths_Caption=FTP 服务器使用特殊的(本地的)月份名称:
mFTPConnect_Caption=FTP 连接
mFTPCreateDir_Caption=建立目录
mFTPDelete_Caption=删除文件/目录
mFTPDisconn_Caption=从 FTP 断开
mFTPEdit_Caption=直接在 PSPad 编辑
mFTPGoRoot_Caption=根目录
mFTPGoWork_Caption=默认目录
mFTPNewFile_Caption=新文件
mFTPRefresh_Caption=刷新
mFTPRename_Caption=重命名
mFTPSendRaw_Caption=发送 FTP RAW 指令
mFTPUploadFile_Caption=上传文件
rs_FTPCopyConn=复制站点
rs_FTPExists=连接"%s"已存在!
rs_FTPNewName=输入新名称:
tbOpenFileDir_Caption=与文件同步
[New File]
cTemplName_Caption=文件名称跟模板名称相同
tabEmpty_Caption=新建文件
tabTemplate_Caption=使用模板
[Links]
lLinkGroup_Caption=群组:
lLinkPath_Caption=路径:
mPSPadOpen_Caption=使用 PSPad 打开
rs_LinkDir=目录
rs_LinkFile=文件
rs_LinkMisc=工具
rs_LinkWeb=WWW
rs_LinkScript=脚本
tbEditLink_Caption=编辑连接
tbNewLink_Caption=新建连接...
[Clipboard monitor]
aClpBrdActivate_Caption=开始/停止监视
aSelectAllItems=选择所有项目
aTrash_Caption=删除全部
[Base calculator]
lAny_Caption=基底:
lBin_Caption=二进制:
lDec_Caption=十进制:
lHex_Caption=十六进制:
lRom_Caption=罗马数字:
lTime_Caption=时间:
[Text diff]
mDiffFromLeft_Caption=来自左侧的差异
mDiffFromRight_Caption=来自右侧的差异
mDiffOneFile_Caption=两个窗口合并成一个新文件
mDiffOnly_Caption=将缺少的行输出成一个新文件
tbDiffRefresh_Caption=重新比对
tbResults_Caption=处理结果
[Variables]
tabVarProg_Caption=程序
tabVarSyst_Caption=系统
tabVarUser_Caption=用户
[CMD window]
cCommandCom_Caption=在 MS-DOS 命令解析器下执行
gbCommand_Caption=命令:
lDefaultDir_Caption=默认目录:
[Hex Editor]
lBytesPerCol_Caption=每列字节数:
lBytesPerLine_Caption=列数:
rDecOffset_Caption=十进制偏移
rHexOffset_Caption=十六进制偏移
[MD generator]
lDigestType_Caption=哈希类型:
lMD5Text_Caption=哈希:
lMD5Verify_Caption=输入哈希值以验证:
lSourceFile_Caption=计算文件哈希值:
lSourceText_Caption=计算字符串哈希值:
rs_MD5FileTooLarge=文件太大了。上限为 250MB。
[Expression Evaluator]
bInsertResult_Caption=粘贴结果
lExpression_Caption=表达式:
lResult_Caption=结果:
[LoremIpsum]
cParagraphEntity_Caption=插入 HTML 段落标签
lDictionary_Caption=字典生成器:
lParCount_Caption=段落数:
lWordsPerPar_Caption=每段的单词数:
rGeneralText_Caption=常规文本
rPoetry_Caption=诗歌般的排版
[Sessions]
bSessionOpen_Caption=打开会话(&O)
bSessionDelete_Caption=删除会话(&D)
cSessionCloseFiles_Caption=打开新会话前先关闭文件(&C)
[Version]
bOpenDevel_Caption=下载开发版
bOpenFull_Caption=下载完整版
bUpdaterManual_Caption=运行更新程序界面
bUpdaterAuto_Caption=自动更新
lManualDownload_Caption=从网络下载更新
lPSPadUpdater_Caption=PSPad 编辑器更新程序
lVersCurrent_Caption=当前 PSPad 版本:
lVersDevelop_Caption=可用开发版本:
lVersFull_Caption=可用完整版:
[FileList]
lFilter_Caption=&Filter:
[CPBatchConvert]
bStartConversion_Caption=开始转换
bLoadFileList_Caption=加载文件列表
lCPInput_Caption=输入 CP 编码:
lCPOutput_Caption=输出 CP 编码:
lInputFolder_Caption=输入文件夹:
lOutputFolder_Caption=输出文件夹:
Posted by: QWERT | Date: 2026-10-24 11:19 | IP: IP Logged
For 5.5.3(891)
; ChineseGB localization for PSPad text editor v5.5.3(891)
[Author]
[Common]
[Action List]
aClose_Hint=关闭当前文件
aCompile_Caption=编译
aCut_Caption=剪切(&T)
aDelete_Caption=删除
aDelete_Hint=删除所选文本
aExit_Hint=退出本程序
aFind_Caption=搜索...
aFind_Hint=搜索文本
aFont_Caption=字体...
aFont_Hint=更改字体
aIndent_Hint=区块缩进
aLineNum_Caption=行号
aMarkList_Hint=书签列表
aNew_Hint=创建新文件
aOpen_Hint=打开所选文件
aPrint_Hint=打印打开的文件
aProjInfo_Hint=工程信息
aProjNew_Hint=打开新工程
aRedo_Caption=恢复
aRedo_Hint=恢复上次撤销
aRollBar_Caption=标尺
aSave_Hint=保存文件
aSort_Caption=排序...
aSpell_Caption=拼写检查
aSpell_Hint=拼写检查
aSyntax_Caption=语法
aUndo_Caption=撤消
aUndo_Hint=撤消上次更改
[Main Menu]
mExport_Caption=导出
mHTML_Caption=&HTML
mMacro_Caption=宏
mPanels_Caption=工具栏
[General Strings]
rs_All=全部(&A)
rs_AllFiles=所有文件
rs_Apply=应用
rs_Asterisk=信息
rs_Bookmark=书签
rs_Cancel=取消
rs_Center=置中
rs_Changed=已修改
rs_Char=字符
rs_Close=关闭
rs_CodeFolding=代码折叠
rs_CodePage=代码页:
rs_CPLat=OEM (DOS)
rs_Dec=Dec
rs_Hex=Hex
rs_Uni=Uni
rs_Entity=条目
rs_Default=默认值
rs_Direction=方向
rs_Down=底部
rs_Error=错误
rs_Exclamation=注意
rs_ExportAs=导出为
rs_File=文件名
rs_FileHint1=左键选取文件
rs_FileName=文件名:
rs_FilesName=名称
rs_FilesSize=大小
rs_FilesType=类型
rs_FilesRights=权限
rs_Find=查找(&I)
rs_Folder=文件夹
rs_Insert=插入
rs_LastUsed=上次使用
rs_LineNumber=行号:
rs_Lines=行
rs_Macro=宏
rs_MacroSave=输入宏名称:
rs_Modify=修改...
rs_NewDir=输入新的目录名称:
rs_NewFile=新建
rs_No=否(&N)
rs_None=无
rs_NoToAll=全部否(&O)
rs_OK=确定(&O)
rs_Options=选项
rs_OverWrite=覆盖
rs_Page=页面:
rs_Password=密码:
rs_Path=路径
rs_Position=绝对位置:
rs_Programs=应用程序
rs_Project=新建工程
rs_Question=确认
rs_Repeat=重复(&R)
rs_Replace=替换(&R)
rs_RowNumber=列:
rs_Scope=范围
rs_Syntax=语法:
rs_Total=合计
rs_Up=Top
rs_UserName=用户名:
rs_UserParam=用户参数
rs_Value=值
rs_Variable=变量
rs_Warning=警告
rs_WWWAddress=网络链接
rs_Yes=是(&Y)
rs_YesToAll=全部是(&A)
[Find Replace]
[About dialog]
lAdress_Caption=地址:
lAuthor_Caption=作者:
[Print Preview]
bExit_Hint=退出预览
FirstCmd_Hint=第一页
Fitto_Caption=适合整页
LastCmd_Hint=最后一页
NextCmd_Hint=下一页
PrevCmd_Hint=上一页
ZoomCmd_Hint=缩放
[Template]
FormCaption=新文本片段
[Settings]
bBracket_Caption=括号
bShellExtRegister_Caption=重新注册右键集成
bShellExtRegister_Hint=取消系统右键集成注册并重新注册
bSpell_Caption=拼写检查
cbStyle_Hint=程序样式主题
cbackUpDir_Caption=文件备份文件夹 (留空使用 TEMP 文件夹):
lBackupTime_Caption=添加日期时间 (file.ext.yyyymmdd~hhnnss). 10个版本
lNew_Caption=新默认值:
lRegTyp_Caption=类型:
rs_tabBackup=备份
rs_tabColors=颜色
rs_tabDialogs=确认
rs_tabFiles=文件和目录
rs_tabHTMLTool=工具
rs_tabInternet=互联网
rs_tabKeyMap=热键映射
rs_tabLanguage=语言
rs_tabSystem=系统集成
rs_tabTextDiff=文件差异
rs_tabUpdates=更新
[HTML color dialog]
[Sort dialog]
cColumn_Caption=指明列
rNumber_Caption=数值
[Page setup dialog]
cBegin_Caption=从行首
cEnd_Caption=从行尾
cInside_Caption=文本内
[DateTime dialog]
bAdd_Caption=添加(&A)
lDate_Caption=日期:
lTime_Caption=时间:
[Find in files]
[User Highlighter]
cLabel_Caption=标签
FormCaption=自定义语法高亮
bAdd_Caption=添加(&A)
bDel_Caption=删除(&D)
FormCaption=高亮器设置
rs_CommandLine=命令行:
[FindHex dialog]
[GotoHex dialog]
[Code Explorer]
aCollapseNode=收起子节点
aExpandNode=展开子节点
aInsertInto=插入到编辑器
aRefresh=更新
aSortAZ=升序排序
aSortZA=降序排序
aSynchronize=与编辑器同步
[Spell check]
[Mail form]
rs_ErrDesc2=如何重现错误:
[Calculate block]
lAvg_Caption=平均:
lCnt_Caption=计数:
lMax_Caption=最大值:
lMin_Caption=最小值:
lSum_Caption=总和:
[Macro Manager]
[Statistics]
rs_Chars=字符
rs_CharsCount=字符计数
rs_Created=建立时间
rs_FileSize=文件大小
rs_Frequency=频率
rs_LastWrite=上次修改时间
rs_LinesCount=行数
rs_MaxLength=行最大长度
rs_ThisVersion=这个版本
rs_Words=单词
rs_WordsCount=单词计数
[Show color]
[Insert text]
rNumber_Caption=编号
rPoint_Caption=项目符号
rText_Caption=文本
[Google search]
[CPCustomize]
rs_Code=代码
rs_Name=编码名称
rs_WebCode=HTML 代码
rs_Autodetect=自动检测
[FTP]
gbGroup_Caption=群组
gbOther_Caption=其他
gbOwner_Caption=拥有者
rs_FTPCopyConn=复制站点
[New File]
[Links]
rs_LinkDir=目录
rs_LinkFile=文件
rs_LinkMisc=工具
rs_LinkWeb=WWW
rs_LinkScript=脚本
[Clipboard monitor]
aTrash_Caption=删除全部
[Base calculator]
lAny_Caption=基底:
lBin_Caption=二进制:
lDec_Caption=十进制:
lHex_Caption=十六进制:
lRom_Caption=罗马数字:
lTime_Caption=时间:
[Text diff]
[Variables]
[CMD window]
[Hex Editor]
[MD generator]
lResult_Caption=结果:
[LoremIpsum]
[Sessions]
[Version]
[FileList]
[CPBatchConvert]
