You are here: PSPad forum > Translation > Dutch
Posted by: Lode | Date: 2007-09-18 23:38 | IP: IP Logged
In the Dutch translation two strings are not very well translated:
aPrintPrev_Caption=Voorbeeld afdrukken
aPrintPrev_Hint=Voorbeeld afdrukken
Would be better like this:
aPrintPrev_Caption=Afdruk voorbeeld
aPrintPrev_Hint=Afdruk voorbeeld
This is the difference between someling like "print a preview" and "preview the print".
--Lode
Posted by: Stefan | Date: 2007-09-19 05:39 | IP: IP Logged
Lode:In the Dutch translation two strings are not very well translated:---
---This is the difference between something like
"preview the print".--Lode
Hi Lode,
i see no "Dutch" language file, only an "Nederlands.ini"
Did you mean this?
And this "Nederlands.ini" have to be updated in general.
There are a lot of string to be translated into dutch.
In this "Nederlands.ini" you will find the author of this language ini.
Would you please contact him and ask him to update the ini
or did you want to update the ini?
Send then the new "Nederlands.ini" or "Dutch.ini" to Support at PSPad.
Thanks
Posted by: waleed333 | Date: 2015-03-03 06:57 | IP: IP Logged
aliiiiii
Posted by: pspad | Date: 2015-03-03 07:12 | IP: IP Logged
waleed333:In this "Nederlands.ini" you will find the author of this language ini.
I am afraid if author didn't update translation long time, he won't do it.
Is it possible for you to update it?
Open file .\Lang\Nederlands.ini (it's plain text file)
look for: ;;translate
this comment marks all missing strings (there is 47 strings)
translate part of the strings behind the equal sign.
If you have installed PSPad in program files, you will need run PSPad as administrator to have rights to write there.
