You are here: PSPad forum > Translation > Spanish (No. 2)
Posted by: | Date: 2003-07-27 14:52 | IP: IP Logged
Hi guys
I've almost finish a 1st try of a spanish translation of PSpad, and i wat some peer review, if anybody a spanish speaker ?
I've some words that need a better translation...
Regards
Edited 2 time(s). Last edit at 2006-07-23 17:23 by Stefan.
Posted by: Juan Fra | Date: 2003-12-18 10:20 | IP: IP Logged
Hi Hernán!
I could test your Spanish file. As a Spanish user I can test your file for
Spanish from Spain (I am aware that there are words and expressions different
from American Spanish).
I hope to hear from u soon,
Juan Fra
Posted by: hernanx | Date: 2003-12-18 17:38 | IP: IP Logged
Juan!
Nice to hear from you !
Yes, sure we can work ajusting the 'diferences of Spanish' we may have.
Let me review the file again and make a preliminary list, you can do that
too, so we have a start.
Hernán
Posted by: Juan Fra | Date: 2003-12-19 10:13 | IP: IP Logged
Hi Hernán!
The fact is that I have no Spanish file at the moment but I can review yours if you
send it to me (or tell me where can I get it).
The Spanish file I use is made by a friend of mine and it is not a serious translation
effort as it is only partially translated and it doesn't use a standard vocabulary.
I hope to have news from u soon
Juan Fra
Posted by: hernanx | Date: 2003-12-22 11:30 | IP: IP Logged
Juan
You can get the latest Spanish File from this tread, there is a msg from
Jan about translations files for the beta build, i have that as updated as
can.
If you have any problem let me know, i can send it directly to your mail.
Hernán
Posted by: Juan Fra | Date: 2003-12-23 21:44 | IP: IP Logged
Thanks Hernán!
Shortly later sending my last post I realized that I had your file because it was
included in the PSPAD download package.
Well, now I am a bit lost. what do you have in mind?
Do you want I revise exhaustively the file writing down possible mistakes and
or European/American Spanish vocabulary?
Any other plan of work?
I hope to read you soon
Juan Fra
Posted by: Juan Fra | Date: 2004-01-08 17:52 | IP: IP Logged
Hi Hernan!
I've been using PSPAD with Spanish translation and I've found a error in it.
There are 2 entries in which the word "esterna" is used. Unfortunately there is a spelling mistake. The correct word is "externa".
I go on using the Spanish localization, and I'll keep you informed of any spelling mistake, european/american Spanish difference, etc...
Anyway, I think your job is excellent, it is a big effort and the translations are
really accurate. Cheers! Hernan
Hope to read you soon
Juan Fra
P.S.: Happy new year
Posted by: Juan Fra | Date: 2004-01-08 18:07 | IP: IP Logged
Hi again!
An European/American issue:
-American use: "ejecutar luego de la compilación"
-European use: "ejecutar después de la compilación"
It sounds strange but it is understandable for European Spanish speakers.
An string length issue:
The string for menu option:
Configuraciones->Configurar resaltadorers...->Compilador->(second checkbox)
is longer than PSPAD allows, so it is truncated in the middle of "programa" word.
This happens no matter the programming language you choose.
Juan Fra
Posted by: hernanx | Date: 2004-02-16 13:47 | IP: IP Logged
Hi Juan !
Sorry the delay but I took some days off and didn't check the mails.
Well, I'm back and with some work waiting, Jan have a new realice
comming and send an updated file with some string, could you help me with
this two specific lines ?
aDropper_Caption=EyeDropper
aDropper_Hint=Capture Color from Screen pixel
by the way, i took yor option about "luego/después", so translate all to después,
and fix the "Resaltadores" issue to
cCompCapture_Caption=Capturar salida del programa
let me know what you think about.
Hernán.
Posted by: Juan Fra | Date: 2004-04-08 10:57 | IP: IP Logged
Hi Hernán!
I think both have been really bussy this last months. Sorry for my
delay too.
I just downloaded last PSPAD version now. I have checked the entries
you remark me in your last post and I think they are really
accurate (in fact I don't know how to translate EyeDropper into
Spanish. BTW what's and Eyedropper? )
Well, I'll try to play a bit with this last version and tell you any
improvements that I will be able to think about.
Felices vacaciones de Semana Santa
Juan Fra
