You are here: PSPad forum > Bug report / Hlášení chyb > Re: Error in v5.5.2 (851) when opening a project
Posted by: Moonytec | Date: 2026-10-21 10:02 | IP: IP Logged
Exception description:
When I open a project, the following error message almost always appears.
Access violation at address 00007FF60CA4A350 in module 'PSPad.exe' (offset 53A350). Read of address 0000000000000630.
Exception address: 00007FF60CA4A350
Stack list, generated 21/10/2026 09:41:05
[00007FF60CA4A350] SynEdit.TCustomSynEdit.GetWordWrap (Line 9810, "SynEdit.pas" + 1) + $4
[00007FF60C95EDA2] JclDebug.JclCreateStackList (Line 5564, "JclDebug.pas" + 1) + $3E
[00007FF60C95ECF2] JclDebug.DoExceptionStackTrace (Line 5505, "JclDebug.pas" + 20) + $1F
[00007FF60C961C6B] JclDebug.DoExceptNotify (Line 6997, "JclDebug.pas" + 7) + $0
[00007FF60C94C332] JclHookExcept.TNotifierItem.DoNotify (Line 272, "JclHookExcept.pas" + 5) + $1D
[00007FF60C94C59C] JclHookExcept.DoExceptNotify (Line 339, "JclHookExcept.pas" + 13) + $2B
[00007FF60C94C771] JclHookExcept.HookedExceptObjProc (Line 395, "JclHookExcept.pas" + 5) + $0
[00007FF60C521BD7] System.@DelphiExceptionHandler + $267
[00007FFFD5BC497F] Unknown function at __chkstk + $12F
[00007FFFD5B5192E] Unknown function at RtlVirtualUnwind2 + $35E
[00007FFFD5BC397E] KiUserExceptionDispatcher + $2E
[00007FF60CF5CB10] uMain.TfPSPad.aProjShowExecute (Line 8370, "uMain.pas" + 34) + $35
[00007FF60CF623AC] uMain.TfPSPad.ProjLoadIt (Line 9428, "uMain.pas" + 200) + $0
[00007FF60CF5163E] uMain.TfPSPad.RecentProjClick (Line 5273, "uMain.pas" + 9) + $10
[00007FF60C8C4FCE] Vcl.Menus.TMenuItem.Click + $EE
[00007FF60C8C7864] Vcl.Menus.TMenu.DispatchCommand + $24
[00007FF60C8C9B39] Vcl.Menus.TPopupList.WndProc + $C9
[00007FF60C8C9A38] Vcl.Menus.TPopupList.MainWndProc + $28
[00007FF60C667306] System.Classes.StdWndProc + $26
[00007FFFD4A30089] Unknown function at CallWindowProcW + $419
[00007FFFD4A2FA02] Unknown function at DispatchMessageW + $1E2
[00007FF60C89E025] Vcl.Forms.TApplication.ProcessMessage + $135
[00007FF60C89E098] Vcl.Forms.TApplication.HandleMessage + $18
[00007FF60C89E4DF] Vcl.Forms.TApplication.Run + $EF
[00007FF60CF9B85B] PSPad.PSPad (Line 121, "" + 57) + $0
[00007FFFD3F44CC0] BaseThreadInitThunk + $10
[00007FFFD5B9EDBB] RtlUserThreadStart + $2B
Program : C:\PSPad editor\PSPad.exe 5.5.2 (851)
System : Windows Server 2022 Server x64, Version: 10.0, Build: 4F7C,
Processor: Intel, Intel(R) Xeon(R) Gold 6146 CPU @ 3.20GHz, 3190 MHz MMX
Display : 3440x1440 pixels, 32 bpp PPI: 96
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_F64718637"
Posted by: pspad | Date: 2026-10-21 10:04 | IP: IP Logged
Visit the PSPad forum and download the latest bit build 5.5.3
from the PSPad developer forum at www.pspad.com.
Replace the existing files with the contents of the archive.
This build contains a fix for your problem.
Posted by: Moonytec | Date: 2026-10-21 10:41 | IP: IP Logged
Still the same error
Access violation at address 00007FF7BEE97F40 in module 'PSPad.exe' (offset 537F40). Read of address 0000000000000630.
Exception address: 00007FF7BEE97F40
Stack list, generated 21/10/2026 10:38:59
[00007FF7BEE97F40] SynEdit.TCustomSynEdit.GetWordWrap (Line 9868, "SynEdit.pas" + 1) + $4
[00007FF7BEDABE92] JclDebug.JclCreateStackList (Line 5564, "JclDebug.pas" + 1) + $3E
[00007FF7BEDABDE2] JclDebug.DoExceptionStackTrace (Line 5505, "JclDebug.pas" + 20) + $1F
[00007FF7BEDAED5B] JclDebug.DoExceptNotify (Line 6997, "JclDebug.pas" + 7) + $0
[00007FF7BED99422] JclHookExcept.TNotifierItem.DoNotify (Line 272, "JclHookExcept.pas" + 5) + $1D
[00007FF7BED9968C] JclHookExcept.DoExceptNotify (Line 339, "JclHookExcept.pas" + 13) + $2B
[00007FF7BED99861] JclHookExcept.HookedExceptObjProc (Line 395, "JclHookExcept.pas" + 5) + $0
[00007FF7BE971BD7] System.@DelphiExceptionHandler + $267
[00007FF7BF3BE1E0] uMain.TfPSPad.aProjShowExecute (Line 8520, "uMain.pas" + 35) + $35
[00007FF7BF3C38F5] uMain.TfPSPad.ProjLoadIt (Line 9583, "uMain.pas" + 203) + $0
[00007FF7BF3B2CDE] uMain.TfPSPad.RecentProjClick (Line 5383, "uMain.pas" + 9) + $10
[00007FF7BED1650E] Vcl.Menus.TMenuItem.Click + $EE
[00007FF7BED18DA4] Vcl.Menus.TMenu.DispatchCommand + $24
[00007FF7BED1B079] Vcl.Menus.TPopupList.WndProc + $C9
[00007FF7BED1AF78] Vcl.Menus.TPopupList.MainWndProc + $28
[00007FF7BEAB7276] System.Classes.StdWndProc + $26
[00007FF7BECEF565] Vcl.Forms.TApplication.ProcessMessage + $135
[00007FF7BECEF5D8] Vcl.Forms.TApplication.HandleMessage + $18
[00007FF7BECEFA1F] Vcl.Forms.TApplication.Run + $EF
[00007FF7BF3FD93B] PSPad.PSPad (Line 124, "" + 59) + $0
Program : C:\PSPad editor\PSPad.exe 5.5.3 (883)
Skin : Windows
TfChildEdit "fEdit_B08417514"
Posted by: pspad | Date: 2026-10-21 10:49 | IP: IP Logged
Thank you, I will check it.
I fixed some problem with 64b version and WordWrap in 5.8.3, but as I see some problems stays
As the workaround you can switch off WordWrap mode (Ctrl+W or Tool icon od menu View) (if possible)
Edited 1 time(s). Last edit at 2026-10-21 10:51 by pspad.
Posted by: Moonytec | Date: 2026-10-21 11:36 | IP: IP Logged
I never had the word-wrap feature enabled, yet the error message still appeared.
Strange.
In the past, I’ve also frequently encountered an error where, after saving, the content of a random line near the beginning of the file would be replaced by some arbitrary Unicode characters.
Apart from that, I also experience occasional crashes involving memory access errors. Could this be related to the virtual server? That said, all other programs run in this environment without any issues.
Posted by: pspad | Date: 2026-10-21 11:56 | IP: IP Logged
Send me future exception logs please - it really helps fix problems.
I hope the problem with project loading has been fixed (future build).
Many problems in 64b version has been fixed in 5.5.3 as well.
