You are here: PSPad forum > Bug report / Hlášení chyb > Bugs in 5.5.2 (851)
Posted by: Ruud | Date: 2026-09-10 19:59 | IP: IP Logged
1) When changing from one project to another, I loose my tabs. I have to restart to get them back.
2) When working with assembly, macros don't work. The tab "macros" is greyed out under tools.
3) When working with HTML, after the first "<!--" to comment out a part of HTML, everything after it is greyed out.
I went back to 5.5.1 (825) and things worked fine again.
Met vriendelijke groet / kind regards, Ruud Baltissen
www.baltissen.org
Edited 1 time(s). Last edit at 2026-09-10 19:59 by Ruud.
Posted by: pspad | Date: 2026-09-10 20:14 | IP: IP Logged
Thank you for reporting.
The problem with multi line comment is fixed already (future build).
I will check rest of points as soon, as I will be back from vacation
Posted by: pspad | Date: 2026-09-18 09:48 | IP: IP Logged
I am back to your point:
Quote:When working with assembly, macros don't work. The tab "macros" is greyed out under tools.
What do you mean by "working with assembly" ?
