You are here: PSPad forum > Bug report / Hlášení chyb > PHP variable double click does not select $ dollar sign
Posted by: peter.feldhammer@gmx.net | Date: 2026-09-09 08:12 | IP: IP Logged
Since the latest version 5.5.2 (581):
Editing a PHP file (HTML multihighliter is shown) if I double click a variable it does not select the dollar sign ($), it selects only the letters after the dollar sign.
So if I double click $var only var is selected.
Posted by: peter.feldhammer@gmx.net | Date: 2026-09-22 13:48 | IP: IP Logged
This problem is also with umlauts.
If I edit a Shell Script xy.sh (Highlighter UNIX Shell Script, Format Unicode UTF-8 no BOM (65001)) and double click the word "Österreich" only "sterreich" is selected.
Best regards Peter
Posted by: pspad | Date: 2026-09-22 16:31 | IP: IP Logged
PHP variable is already fixed in developer build - available in the developer forum
I can confirm problem Accented signs in some highlighters.
I will check it.
Posted by: pspad | Date: 2026-09-22 16:38 | IP: IP Logged
Quote:This problem is also with umlauts.
If I edit a Shell Script xy.sh (Highlighter UNIX Shell Script, Format Unicode UTF-8 no BOM (65001)) and double click the word "Österreich" only "sterreich" is selected.Best regards Peter
Fixed. Available in the next build
Edited 1 time(s). Last edit at 2026-09-22 16:38 by pspad.
