You are here: PSPad forum > Bug report / Hlášení chyb > Re: Does NOT minimize to tray on Exit
#1 Does NOT minimize to tray on Exit
Posted by: Franklinger | Date: 2026-08-06 15:54 | IP: IP Logged
If Setting "Minimize to Tray on Exit" is activated, PSPad close all Files when Exiting but does NOT minimize.
Bug since 5.5.2.845 beta
PSPad now running on Windows 10 64bit (1809 - Build 17763.9020)
Will soon check other Windows Versions
#2 Re: Does NOT minimize to Tray on Exit
Posted by: Franklinger | Date: 2026-08-06 16:25 | IP: IP Logged
Franklinger:
PSPad now running on Windows 10 64bit (LTSC 2019 - Build 17763.9020)
This happens with all Windows Versions I can Boot on my PC (with PSPad 32bit & PSPad 64bit):
Windows XP [32bit]
Server 2003 [32bit]
Windows 7 [32bit & 64bit]
Windows 10 [32bit - LTSC 2021 Build 19044.7548]
#3 Re: Does NOT minimize to tray on Exit
Posted by: pspad | Date: 2026-08-07 04:17 | IP: IP Logged
I will look for it and fix it.
#4 Re: Does NOT minimize to tray on Exit
Posted by: pspad | Date: 2026-08-20 07:45 | IP: IP Logged
Fixed from 5.5.3 (855)
