You are here: PSPad forum > Bug report / Hlášení chyb > Re: Tab title has no padding from the right
Posted by: xterm | Date: 2025-09-25 09:46 | IP: IP Logged
It's just cosmetic, but I notice it every time I use the Editor and I have a feeling it was not present in earlier versions.
Tried fixing it by adding spaces at the end of Tab Title Format string, but thats 1) not the right solution 2) those spaces are being trimmed .)
Also, if it is solely win 10 issue, ignore please, since we are all moving to win 11 anyway soon. Thank you
Posted by: pspad | Date: 2025-09-25 11:30 | IP: IP Logged
PSPad version please?
Posted by: pspad | Date: 2025-09-25 13:17 | IP: IP Logged
As workarround:
Open new file
Open ASCII chart, find char 160 ( )
Double click 2 times on space char in the tab
Copy it and paste on the end of tab format in the program settings. Those solid spaces won't be trimmed
Posted by: xterm | Date: 2025-09-25 18:57 | IP: IP Logged
5.5.1 (825)
Successfully applied workaround, thank you!
Funny enough, I actually tried exactly that after the regular spaces had been trimmed. By copy-pasting a non-breaking space from a Wikipedia article, but it seems that when copying from a browser, a normal space (20) gets pasted. I should have used the PSPad ASCII chart from the start!
Posted by: pspad | Date: 2025-09-26 04:08 | IP: IP Logged
In the next build, I will add space there automatically
