You are here: PSPad forum > Bug report / Hlášení chyb > Last document has disappeared after start-up.
Posted by: Ruud | Date: 2025-02-09 17:37 | IP: IP Logged
If you close PSPad and later start it again, the last document on the screen has disappeared but its tab is still visible. It only happens when the last document was focused when PSPad was shut down. By first clicking another tab and then the last one, you will see the document again.
Version 5.5.1 (825)
Met vriendelijke groet / kind regards, Ruud Baltissen
www.baltissen.org
Edited 1 time(s). Last edit at 2025-02-09 17:39 by Ruud.
