You are here: PSPad forum > Bug report / Hlášení chyb > User highlighter definition does use well case sensitivity
#1 User highlighter definition does use well case sensitivity
Posted by: Philippe Allain | Date: 2025-01-30 14:41 | IP: IP Logged
Using version 5.5.1
In one of the 4 lists of the User Highlighter definition window:
I enter:
$(Password)
$(PASSWORD)
but only $(Password) is remembered even though the setting 'Words are case sensitive' is checked.
Great program anyway. Thanks.
Philippe Allain
BNF Software
France
#2 User highlighter definition does NOT use properly case sensitivity
Posted by: Philippe Allain | Date: 2025-01-30 14:47 | IP: IP Logged
There was a mistake in the title of my previous message. Sorry.
#3 User highlighter definition does NOT use properly case sensitivity
Posted by: Philippe Allain | Date: 2025-01-30 14:48 | IP: IP Logged
Should read:
#4 Re: User highlighter definition does use well case sensitivity
Posted by: pspad | Date: 2025-01-31 05:16 | IP: IP Logged
You are right, there is a problem in the PSPad.
Check Words are case sensitive and Save Highlighter
Add your both keywords.
I will fix it in the next build.
#5 Re: User highlighter definition does use well case sensitivity
Posted by: pspad | Date: 2025-02-05 14:06 | IP: IP Logged
Fixed in current full version 551
