You are here: PSPad forum > Bug report / Hlášení chyb > Re: PsPad 5.0.7 - crash with textfile
Posted by: herb | Date: 2025-01-11 10:46 | IP: IP Logged
I work with PsPad 32bit 5.0.7 - 775 on my Windows 10 system.
When I try to open the textfile PsPad crashes with an access violation.
The exception description and the textfile will be sent by mail.
After pressing OK it seems to be possible to work with PsPad, the read file is marked as modified, but the splash-screen is always on top.
Thanks for your help in advance.
Best regards
herb
Posted by: pspad | Date: 2025-01-11 13:50 | IP: IP Logged
It looks like there is anything in your inno setup file what highlighter doesn't count with.
Can you send me your file to support mail?
Posted by: herb | Date: 2025-01-11 15:25 | IP: IP Logged
thanks for your reply.
Yes you are right. After I had disabled all highlighters I could not reproduce the crash.
I hope you got the file. I have sent it to support at ...
Best regards
herb
Posted by: herb | Date: 2025-01-13 12:01 | IP: IP Logged
in my last post I said: "After I had disabled all highlighters I could not reproduce the crash."
Sorry to say, this it not true.
After adding some more strings like {#text} to the file I sent and the crash is back.
Best regards
herb
