You are here: PSPad forum > Bug report / Hlášení chyb > "Open Special/Recent" files doesn't work anymore
#1 "Open Special/Recent" files doesn't work anymore
Posted by: OmaJantzen | Date: 2024-12-10 11:10 | IP: IP Logged
PSPad Version 5.0.7 (775) 32 bit; Windows 10 64 bit
The “Save recent items” option in the program settings is set.
Recent.INI in %Appdata% is available and not write-protected.
Find and Replace-Items are being recorded.
Only elements from the most recent files are not updated.
Not even after clearing the entries (manually or via menu entry).
#2 Re: "Open Special/Recent" files doesn't work anymore
Posted by: pspad | Date: 2024-12-10 12:12 | IP: IP Logged
hello
What does it means? Do you mean not all files are stored or?
#3 Re: "Open Special/Recent" files doesn't work anymore
Posted by: OmaJantzen | Date: 2024-12-10 15:14 | IP: IP Logged
Yes, file list is empty. No historic files saved.
File/Change history is OK.
#4 Re: "Open Special/Recent" files doesn't work anymore
Posted by: OmaJantzen | Date: 2024-12-10 15:21 | IP: IP Logged
Funny enough - now it seems to work.
I'll keep an eye on it.
