You are here: PSPad forum > Bug report / Hlášení chyb > Bad codepage detection when file starts with Úš
#1 Bad codepage detection when file starts with Úš
Posted by: khagaroth | Date: 2024-10-15 06:48 | IP: IP Logged
If a Windows-1250 file starts with the combination of characters Úš (note, case is important, úš doesn't cause this), PsPad stubbornly insist on opening it as UTF-8 and obviously complains about bad UTF-8 encoding. PsPad 5.0.7.775, Windows 11.
#2 Re: Bad codepage detection when file starts with Úš
Posted by: pspad | Date: 2024-10-15 07:04 | IP: IP Logged
Diky, prověřím.
Jde to i tak, že po otevření souboru se změní kodovani na 1250 a soubor se prenacte (Ctrl+R)
Pak by melo zafungovat to vynucene, v tomto pripade 1250
#3 Re: Bad codepage detection when file starts with Úš
Posted by: khagaroth | Date: 2025-02-16 08:36 | IP: IP Logged
5.5.1.825 - problém přetrvává.
#4 Re: Bad codepage detection when file starts with Úš
Posted by: khagaroth | Date: 2025-07-12 18:01 | IP: IP Logged
5.5.2.831 - stále reprodukovatelné
