You are here: PSPad forum > Bug report / Hlášení chyb > Re: Pspad item in windows explorer context menu : Bug installation
#1 Pspad item in windows explorer context menu : Bug installation
Posted by: RackamLeRouge | Date: 2024-03-05 15:03 | IP: IP Logged
Hello, i want to describe a bug when i install pspad on windows 10, 64 bits système.
When i install pspad on windows 10 (X64 version -> *.exe) shortcut for Pspad item in windows explorer context menu are well install if i am in administrator mode (when i do the installation), but if i try to install pspad in user mode (i enter administrator login and password during installation), shortcut in content menu aren't installed...
I hope this description will help you.
Jean-Baptiste Duclos, France
#2 Re: Pspad item in windows explorer context menu : Bug installation
Posted by: pspad | Date: 2024-03-07 10:08 | IP: IP Logged
I guess when you install it under Admin, you will see the Explorer context menu entries next time you login.
Try to kill Explorer and start it again or logout / Login into OS
