You are here: PSPad forum > Bug report / Hlášení chyb > PSPad unicode 5.5.1 (790) 32b Access violation
Posted by: madragna | Date: 2024-02-02 09:34 | IP: IP Logged
- Work on FTP
- pspad longer then 12 hours open
- 11 tabs open
- Refresh FTP connection with open old tabs
- work in different tabs, save, work - all fine
- switch to an already used tab -> crash
Access violation at address 7F9A0010. Execution of address 7F9A0010.
Exception address: 7F9A0010
Stack list, generated 02/02/2024 10:33:09
(FFFFF010) [7F9A0010]
[006C280A] SynEditKbdHandler.TMethodList.GetItem (Line 377, "SynEditKbdHandler.pas" + 3) + $6
[006C256B] SynEditKbdHandler.TSynEditKbdHandler.ExecuteMouseDown (Line 280, "SynEditKbdHandler.pas" + 6) + $29
[0073FF50] SynEdit.TCustomSynEdit.MouseDown (Line 2005, "SynEdit.pas" + 29) + $15
[0077F195] PSSynedit.TPSSynEdit.MouseDown (Line 425, "PSSynedit.pas" + 2) + $C
[0065EAB0] Vcl.Controls.TControl.DoMouseDown + $88
[0065CE5B] Vcl.Controls.TControl.SetMouseCapture + $17
[0065EAFF] Vcl.Controls.TControl.WMLButtonDown + $3F
[0065E46E] Vcl.Controls.TControl.WndProc + $2BE
[00623E4A] Vcl.Forms.Default + $3A
[00663635] Vcl.Controls.TWinControl.WndProc + $665
[003EB12C] System.TMonitor.TryEnter + $28
[003EAC54] System.TMonitor.Enter + $10
[00623DED] Vcl.Forms.TCustomForm.WndProc + $725
[003EAABC] System.TMonitor.CheckOwningThread + $4
[003EADE2] System.TMonitor.Exit + $6
[003EAE3E] System.TMonitor.Exit + $1A
[00501BC1] Vcl.Graphics.FreeMemoryContexts + $9D
[00662B40] Vcl.Controls.TWinControl.MainWndProc + $2C
[00662B55] Vcl.Controls.TWinControl.MainWndProc + $41
[00662D38] Vcl.Controls.TWinControl.ControlAtPos + $10
[00662DF4] Vcl.Controls.TWinControl.IsControlMouseMsg + $B0
[0074823C] SynEdit.TCustomSynEdit.WndProc (Line 5631, "SynEdit.pas" + 5) + $0
[004C05E0] System.Classes.StdWndProc + $14
[0062E1D7] Vcl.Forms.TApplication.ProcessMessage + $F3
[0062E21A] Vcl.Forms.TApplication.HandleMessage + $A
[0062E559] Vcl.Forms.TApplication.Run + $D1
[00B768A4] PSPad.PSPad (Line 120, "" + 56) + $7
Program : C:\PSPad\PSPad.exe 5.5.1 (790)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A65,
Processor: AMD, AMD Ryzen 9 3900X 12-Core Processor , 3790 MHz MMX
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_H04859326"
