You are here: PSPad forum > Bug report / Hlášení chyb > Autosave & Save: Blank file bug! (0 bytes)
Posted by: lekivej | Date: 2023-11-18 13:48 | IP: IP Logged
It happens with autosave active and pressing save button at the same time. PSPAD crashes, (sometimes Windows reboots too). Entire file is lost (0 bytes).
This bug affects a lot of versions, including version 5.5.1 (790). I'm not sure if hibernating the computer can affect. PSPad was open many days in a row.
I really like this editor and prefer it over other options, however it requires taking certain precautions (autosave disabled and backups).
Posted by: pspad | Date: 2023-11-18 18:02 | IP: IP Logged
Hello.
If you have problem with operating system - I never heard that PSpad causes OS restart, it's possible that sile isn't stored to drive from memory cache - this is OS business.
Posted by: lekivej | Date: 2023-11-18 18:30 | IP: IP Logged
300KB text file gone. I had to restart from the previous week's saved file.
Posted by: pspad | Date: 2023-11-18 18:52 | IP: IP Logged
Do you have no backup activated? PSPad knows it.
Do you save your file locally, on the network or FTP?
Posted by: lekivej | Date: 2023-11-18 19:48 | IP: IP Logged
Backup option was not active in Pspad. It saved locally.
