You are here: PSPad forum > Bug report / Hlášení chyb > Search / Replace in files issue
#1 Search / Replace in files issue
Posted by: MASH73 | Date: 2023-08-28 13:45 | IP: IP Logged
using PSPad 5.5.1 (790).
After using "Search / Replace in files..." all opened documents are blank and no longer editable, same for new opened files and even new blank files.
The linenumbers disappear as well
Is this a known issue ?
Screenshot: ibb.co
Edited 1 time(s). Last edit at 2023-08-28 13:46 by MASH73.
#2 Re: Search / Replace in files issue
Posted by: Ravelli | Date: 2023-08-28 14:54 | IP: IP Logged
I'm using this feature pretty often on different kind of source code and log files, but never experienced this issue. I stress-test it right now by searching in more than 11000 project files and also in a certain folder - all fine. When I open a found file from the file search results, I don't have the little triangle in file tab as shown in your screenshot (indicating file is not saved).
Are you in 32 or 64 bit PSPad?
Edited 1 time(s). Last edit at 2023-08-28 14:55 by Ravelli.
#3 Re: Search / Replace in files issue
Posted by: pspad | Date: 2023-08-28 15:00 | IP: IP Logged
Can you tell me more about original placement of your files? Any shared folder (One drive, Google drive)?
#4 Re: Search / Replace in files issue
Posted by: MASH73 | Date: 2023-08-28 19:46 | IP: IP Logged
OneDrive for Business but also outside like c:\temp with really few files in a folder structure.
I tested that on 3 different devices with the same result.
Windows 10 and Windows 11, PSPad 32-bit.
#5 Re: Search / Replace in files issue
Posted by: MASH73 | Date: 2023-09-02 13:57 | IP: IP Logged
Hi again,
I was able to find out what causes the issue.
Since I'm using PSPad I regularly update to the latest beta.
Since I never overwrote the file PSPad.ini there seems to be wrong entries now
causing the Search / Replace in files
Steps to reproduce:
1.
download and extract pspad.poradna.net
2.
download PSPad.ini from drive.google.com
and save it in the root of PSPad
3.
try Search / Replace in files (I searched in C:\Temp for "test")
#6 Re: Search / Replace in files issue
Posted by: pspad | Date: 2023-11-15 10:28 | IP: IP Logged
Confirmed.
Problem is that PSPad redraw screen stays locked. No content was damaged or destroyed.
Thank you for the INI, I have to find place, where id doesn't unlock redraw.
#7 Re: Search / Replace in files issue
Posted by: pspad | Date: 2023-11-15 10:54 | IP: IP Logged
Problem in your case is that LogHeight is in your case 3962 pixels
LogHeight=3962 (config)
If means, it shows log, but log hides editors. Delete this line from your PSpad.ini
I must handle this situation
