You are here: PSPad forum > Bug report / Hlášení chyb > Indendation (TAB-Key) of multiple (empty) Lines (v5.0.6 different from v5.0.7)
#1 Indendation (TAB-Key) of multiple (empty) Lines (v5.0.6 different from v5.0.7)
Posted by: ChrisAIX | Date: 2023-07-01 12:01 | IP: IP Logged
I have here an issue with indent multiple lines (including empty lines)
Example
* Tabs are configured as 4 space chars
lets say we have the following block marked (all 3 lines)
123¶
456¶
* in v5.0.6
When hitting the TAB key -> *ALL* lines will be indented
····123¶
····456¶
* in v5.0.7
Only lines that are not empty will indented - the empty line will NOT be intended.
····123¶
····456¶
I would like to use the v5.0.6 behavior.
--> Is it possible to configure the v5.0.6 behavior in v5.0.7?
I can't find anything
Many thanks in advance
Chris
Edited 1 time(s). Last edit at 2023-07-01 12:05 by ChrisAIX.
#2 Re: Indendation (TAB-Key) of multiple (empty) Lines (v5.0.6 different from v5.0.7)
Posted by: pspad | Date: 2023-07-01 12:21 | IP: IP Logged
Look at settings if there is no Trim trailing spaces option checked in the program settings / editor
