You are here: PSPad forum > Bug report / Hlášení chyb > Re: incorrect result searching two consecutive empty lines
#1 incorrect result searching two consecutive empty lines
Posted by: stroweis | Date: 2023-06-12 23:25 | IP: IP Logged
I wanted to find if there are two consecutive empty lines in a text file.
So, using regular expression on, I entered the following string:
PsPad moves to the next occurrence where there is one empty line, as if I had asked :
It seems to me that it is an error, although a minor error.
Thank you for the tool.
#2 Re: incorrect result searching two consecutive empty lines
Posted by: pspad | Date: 2023-06-13 04:26 | IP: IP Logged
Pspad searches line by line, not in whole text
#3 Re: incorrect result searching two consecutive empty lines
Posted by: Vany | Date: 2023-07-03 08:54 | IP: IP Logged
and wouldn't it be a great improvement to get the option to use regex on all the content of the file in current editor? and/or in Search/Replace in Files...
