You are here: PSPad forum > Bug report / Hlášení chyb > Re: Can't drop and drag to open from file explorer in tool panel
#1 Can't drop and drag to open from file explorer in tool panel
Posted by: srce | Date: 2023-04-18 13:52 | IP: IP Logged
It's not possible to open a file by dragging and dropping from the file explorer in the tool panel, if there is no empty space in the MDI area. i.e If drop target is an MDI window (a text editor window), then the icon changes to a circle with a line through it. So if the editor windows are maximized, then you can't use drop and drag. It only seems to work by dropping in to empty space.
Note that dragging from the Windows desktop or Windows Explorer, does not have this problem. You can drop anywhere.
Thanks.
#2 Re: Can't drop and drag to open from file explorer in tool panel
Posted by: srce | Date: 2023-04-18 14:04 | IP: IP Logged
Applies to current release and developer 32-bit builds.
#3 Re: Can't drop and drag to open from file explorer in tool panel
Posted by: pspad | Date: 2023-04-18 14:21 | IP: IP Logged
I just test it and it really doesn't work. I will add it.
#4 Re: Can't drop and drag to open from file explorer in tool panel
Posted by: pspad | Date: 2023-04-19 08:37 | IP: IP Logged
Fixed, available in the next build
#5 Re: Can't drop and drag to open from file explorer in tool panel
Posted by: srce | Date: 2023-04-19 08:40 | IP: IP Logged
Thanks!
