You are here: PSPad forum > Bug report / Hlášení chyb > Text difference setting
#1 Text difference setting
Posted by: fyurisich | Date: 2023-04-04 19:33 | IP: IP Logged
Hi, I'm having a problem with field "Diff tool parameters".
I set the field to:
%File1%" "%File2%"
and PSPAD correctly save it to PSPad.ini
but after restarting PSPAD the field content is changed to
%File1%" "%File2%
(starting and ending " are gone).
Thank you.
#2 Re: Text difference setting
Posted by: Andreas | Date: 2023-04-04 20:22 | IP: IP Logged
Try
%File1% %File2%
or try
"%File1%" "%File2%"
You forgot some double quotes in your example.
#3 Re: Text difference setting
Posted by: pspad | Date: 2023-04-05 05:07 | IP: IP Logged
PSPad version? As I remember, this problem was very long ago.
#4 Re: Text difference setting
Posted by: Andreas | Date: 2023-05-15 21:40 | IP: IP Logged
Oh yeah, it still removes the leading and ending quotes after you restart pspad.
5.5.1 783
Without quotes works for me but I don't know what happens if there are spaces in the filename. Almost never have spaces in there.
#5 Re: Text difference setting
Posted by: pspad | Date: 2023-05-18 09:42 | IP: IP Logged
Will be fixed in the next build.
#6 Re: Text difference setting
Posted by: Andreas | Date: 2023-05-18 15:07 | IP: IP Logged
Thank you grinning smiley
