You are here: PSPad forum > Bug report / Hlášení chyb > 5.0.7.770 64bit - Faulting KERNELBASE.dll
Posted by: StephanCanada | Date: 2023-03-10 16:08 | IP: IP Logged
This gets logged in the Event Viewer and happens when exiting PSPad. In my case, I was editing an XML file, saving the changes, exiting. Heard a 'ping' and checked the Event Viewer.
Faulting application name: PSPad.exe, version: 5.0.7.770, time stamp: 0x640b1100
Faulting module name: KERNELBASE.dll, version: 10.0.19041.2546, time stamp: 0xe8e9ac9b
Exception code: 0x0eedfade
Posted by: pspad | Date: 2023-03-10 16:46 | IP: IP Logged
Kernelbase.dll is operating system dll.
I suggest 32b version of PSPad, but users require 64b. It's a fashion?
Posted by: LouCypher | Date: 2023-03-20 07:18 | IP: IP Logged
Just a short comment why the 64bit version can make sense: I often have to investigate large trace files with more than 4Gbyte. This cannot work with the 32bit version so I tried it with the 64bit version. But it didn't work either
Posted by: pspad | Date: 2023-03-20 07:53 | IP: IP Logged
It works. The only problem is report of the crash on close application.
There is no problem to have 2 PSPads together and 64b version use for large files only.
I will try to find reason of this behavior. It's based of compiler, not the source code. Source code is same.
Posted by: LouCypher | Date: 2023-03-21 18:13 | IP: IP Logged
Oh, I didn't refer to the reported problem with the dll. I meant that opening of very large files didn't work with the 64bit build either as I hoped. But nevermind, I don't care about both problems and would be much more happy if the problem with the occasionally injected garbage data could be tracked down.
Edited 1 time(s). Last edit at 2023-03-21 18:15 by LouCypher.
