You are here: PSPad forum > Bug report / Hlášení chyb > Re: Edit > Selection Type > Column Selection is not working
#1 Edit > Selection Type > Column Selection is not working
Posted by: Jörn Hatzky | Date: 2023-03-10 15:32 | IP: IP Logged
Hi Jan,
Edit > Selection Type > Column Selection is not working.
It is only working when using Alt + Left Mouse Key directly.
Kind regards,
Jörn
#2 Re: Edit > Selection Type > Column Selection is not working
Posted by: pspad | Date: 2023-03-10 16:49 | IP: IP Logged
PSPad offers 2 modes:
Alt+mouse as other windows application - in this mode mouse without Alt resets to normal selection.
When you disable alt+mouse in program settings, you can switch selection mode manually
