You are here: PSPad forum > Bug report / Hlášení chyb > Column Select stopped working
#1 Column Select stopped working
Posted by: olehweres | Date: 2022-10-18 20:21 | IP: IP Logged
Version 5.0.6 on Windows 10 Pro, 64 bit.
Column select worked before, but stopped working. Keeps switching back to Normal Select. Tried downloading and installing PSPad Portable, same problem.
#2 Re: Column Select stopped working
Posted by: pspad | Date: 2022-10-19 04:09 | IP: IP Logged
There are 2 mode for column selection:
1. alt+mouse (same as other Windows application)
2. switching mode manually
You have to choose what mode do you want to use. If second one as before, you need to open program settings / Editor 1 and uncheck Alt sets column mode
