You are here: PSPad forum > Bug report / Hlášení chyb > mark that a file changed
#1 mark that a file changed
Posted by: Peter.eisentraeger2 | Date: 2022-09-16 08:48 | IP: IP Logged
Hi Jan, I see you did a great job. I have 735 installed.
Minor bug: when I edit a file the red mark in the top left corner of the tab does not appears instantly. It appears when I activate another tab. When I save the changed file the red mark does not disappear instantly after saving. It again disappears then I activate another tab.
Maybe you restricted the "redraw" to harsh?
Greetings, Peter
#2 Re: mark that a file changed
Posted by: pspad | Date: 2022-09-16 08:52 | IP: IP Logged
Thank you for info. I tried to avoid as much redraw as I was able and maybe it was too much.
#3 Re: mark that a file changed
Posted by: pspad | Date: 2022-09-16 10:39 | IP: IP Logged
I found it occurs in case when buttons as file tabs are selected. For tabs it behaves correctly.
