You are here: PSPad forum > Bug report / Hlášení chyb > Batch Encodind Conversion in PsPad 507
Posted by: Galizar | Date: 2022-03-28 22:16 | IP: IP Logged
After using Batch Encoding Conversion to convert ANSI Autohotkey scripts to Unicode UTF8 BOM 65001, all .AHK files are converted ok but all of them have an extra line at the end of each file
Input Cp Encoding Ansi Default 0
Tested with Autodetect CP On&Off
Output Cp Encoding Unicode UTF8 BOM 65001
Thank you
PsPad 507.727 32Bits // Windows 10 Home 32 Bits
Posted by: Vany | Date: 2022-05-02 13:17 | IP: IP Logged
What is your Setting in Program Settings/Editor (part 1)/Add CR+LF to EOF ?
(PSPad 5.5.2.831 x32, W10h/W11p x64 en/cs)
