You are here: PSPad forum > Bug report / Hlášení chyb > Re: Highlighter doesn't work on bigger files
#1 Highlighter doesn't work on bigger files
Posted by: nerov89383 | Date: 2022-03-16 14:07 | IP: IP Logged
Highlighter stops working on bigger files, I think threshold is somewhere at ~500kb.
It happens with all versions I was using.
My workaround is to open JS file then copy all and paste to a new created file/tab, then highlighting works.
It doesn't work when you open that big file, very annoying issue...
Edited 1 time(s). Last edit at 2022-03-16 14:16 by nerov89383.
#2 Re: Highlighter doesn't work on bigger files
Posted by: pspad | Date: 2022-03-16 17:39 | IP: IP Logged
Program settings / Direct edit button
Change line: HLUpToSize=500000
Value is in bytes - limit under what highlighter is used
#3 Re: Highlighter doesn't work on bigger files
Posted by: nerov89383 | Date: 2022-03-17 08:29 | IP: IP Logged
Thanks for the tip, that solved the issue.
