You are here: PSPad forum > Bug report / Hlášení chyb > Re: Featur request: column for comment insertion
#1 Featur request: column for comment insertion
Posted by: rovf | Date: 2022-02-14 11:03 | IP: IP Logged
"Add/Remove comments" (bound to shift-control-A) is a handy function to comment out a block of lines. The comment character is always inserted at the *start* of the line. I suggest that the insertion is in the column where the selected block starts.
Example:
LINE1 LINE2 LINE3
If I select these lines starting from the "L", up to including LINE3, the commented area should then look like (assuming a # as comment character)
#LINE1 #LINE2 # LINE3
instead of
# LINE1 # LINE2 # LINE3
Ronald Fischer (Germany)
#2 Re: Featur request: column for comment insertion
Posted by: pspad | Date: 2022-02-14 11:13 | IP: IP Logged
What highlighter do you use?
If I tested different internal highlighters, it adds comment char(s) + space and never change indent of one line according to others if I select more lines.
#3 Re: Featur request: column for comment insertion
Posted by: Andreas | Date: 2022-02-14 13:28 | IP: IP Logged
Mmmh, I think it's ok when it starts at first place of the line.
BTW Within PHP "#" is not really a comment. It's used for code deactivating. Comments in PHP are "//" for one line and /* next lines */ for block comments. Standardized block comments for PHP documentation looks like this:
/* * This file is part of project 1. * * (c) John Doe * * @license LGPL-3.0-or-later * @anotherFlag .... */
#4 Re: Featur request: column for comment insertion
Posted by: Andreas | Date: 2022-02-14 13:38 | IP: IP Logged
There is no comment functionality for CSS. If you like to work on it, here are the comments. There's only one comment for CSS.
/* one line */ body { /* background-color: red; */ color: gray; }
/* multiple lines */ /* body { background-color: red; color: gray; } */ I personally use a trick
/* deactivated block */ /** body { background-color: red; color: gray; } /**/
/* activated block */ /**/ body { background-color: red; color: gray; } /**/ The difference is only the missing one slash within the line above "body".
Edited 1 time(s). Last edit at 2022-02-14 13:38 by Andreas.
