You are here: PSPad forum > Bug report / Hlášení chyb > bug at forming searching list
Posted by: compos | Date: 2021-12-28 07:01 | IP: IP Logged
In the procedure "search" I would like to get list of found items as "List" without numbers of lines.
But mark in field "with line numbers" ignored - always we get list with line numbers.
The sequence of actions is following:
1. Cntrl/F
2. specify searching text
3. press button "List" (first left button)
4. in the window of found lines to press the topmost icon "Show results in new window". Field "with line numbers" is empty.
5. We get new window with line numbers.
Is it a bug or I did something wrong?
Sorry, if I specify names of button slightly differed from valid names - I try russian version of PSPAD.
Posted by: pspad | Date: 2021-12-28 07:19 | IP: IP Logged
Use copy butyon instead of the list result into lig and open log.
Line nubers is for Copy button, not for list
