You are here: PSPad forum > Bug report / Hlášení chyb > Re: Access violations in 5.0.7
Posted by: pspad | Date: 2022-02-25 15:55 | IP: IP Logged
You didn't provided any info - what did you do when exception occurred - file close (what way you use to close file) e.t.c.
Posted by: ardjuna | Date: 2022-02-25 16:01 | IP: IP Logged
Yes, closing a file. I have opened multiple files (tabs), then I decide to close some by double clicking the tab, and that's the terminal. It happened on regular basis (many times a day). It seems from other posts that I am definitely not the only one with this problem ...
Edited 1 time(s). Last edit at 2022-02-25 16:02 by ardjuna.
Posted by: ardjuna | Date: 2022-02-26 07:58 | IP: IP Logged
To prove I'm not lying, I reinstalled the latest PSPad 32b and after it froze again, I sent you an email with an error log.
Posted by: pspad | Date: 2022-02-26 08:46 | IP: IP Logged
I didn't accuse you of being a liar. It's just that there have been several times when a user had the 64b version, installed the 32b version, but still ran the 64b version
Posted by: ardjuna | Date: 2022-02-26 11:19 | IP: IP Logged
I did not mean to accuse you. I just wanted to show that 32b version has the same problem. I really admire your work, and I love your PSPad. But right now it is "a pain in the ass". I hope you can find the problem a solve it. That would be great. Good luck with it!
Posted by: pspad | Date: 2022-02-26 11:31 | IP: IP Logged
I hope so. This is a reason, why I collect error reports and try to solve all problems.
Posted by: John Huijsing | Date: 2022-05-10 01:29 | IP: IP Logged
Exception description:
Access violation at address 00000000000000FF in module 'PSPad.exe'. Execution of address 00000000000000FF.
Exception address: 00000000000000FF
Stack list, generated 10/05/2022 11:21:49
(FFFFFFFFFFFFF0FF) [00000000000000FF]
[000000000080A7C8] JclDebug.JclCreateStackList (Line 5351, "JclDebug.pas" + 1) + $3F
[000000000080A736] JclDebug.DoExceptionStackTrace (Line 5292, "JclDebug.pas" + 20) + $15
[000000000080CCD6] JclDebug.DoExceptNotify (Line 6741, "JclDebug.pas" + 7) + $0
[00000000007FA505] JclHookExcept.TNotifierItem.DoNotify (Line 272, "JclHookExcept.pas" + 5) + $11
[00000000007FA74B] JclHookExcept.DoExceptNotify (Line 339, "JclHookExcept.pas" + 13) + $2B
[00000000007FA907] JclHookExcept.HookedExceptObjProc (Line 395, "JclHookExcept.pas" + 5) + $0
[0000000000411767] System.@DelphiExceptionHandler + $267
[00007FFB13F720CF] Unknown function at __chkstk + $11F
[00007FFB13F21454] RtlRaiseException + $434
[00007FFB13F70BFE] KiUserExceptionDispatcher + $2E
Program : C:\PROGRA~2\PSPADE~1\PSPad.exe 5.0.7 (731)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A64,
Processor: Intel, Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2200 MHz MMX
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_J95854731"
Posted by: acastiello | Date: 2022-06-30 16:18 | IP: IP Logged
In my case it started when I upgraded to that version and simultaneously from 32 to 64 bits.
It mainly happens when I launch a file outside PsPad, and by outside I mean windows explorer and Jedi VCS. Most of the time is with .SQL files. It also happens when the clipboard becomes "stuck" (an application didn't close it) but that happened in previous versions
