You are here: PSPad forum > Bug report / Hlášení chyb > Re: Problem with commandline swith /F
Posted by: TCB | Date: 2021-12-06 10:12 | IP: IP Logged
i have a Problem using the /F switch do start a search after a file is opened. The function runs perfekt, if PsPad is not running. If PsPad is still running, the Params where all handled as files.
Posted by: pspad | Date: 2021-12-06 10:41 | IP: IP Logged
Thank you for report, I will check it.
Posted by: pspad | Date: 2021-12-07 12:27 | IP: IP Logged
It works for me in both cases even PSPad is open or not before you run command
But I found a problem - when PSpad open file, it restore position and search starts from this position. It's wrong, search should start from the begin of file.
Maybe it's your problem too, cause it looks like search doesn't work
