You are here: PSPad forum > Bug report / Hlášení chyb > Strange cursor behaviors
Posted by: Extranjero | Date: 2021-10-12 15:57 | IP: IP Logged
In some files opened with PSPad, the vertical cursor stops flashing and remains fixed on a place, but inserting on the desired place works (without having a flashing cursor there ...).
At the same time in other open files cursor desplaces where clicked in code.
Note: all files are of the same type.
PSPad Version 687 64bit, Win10 64bit
Posted by: pspad | Date: 2021-10-12 17:09 | IP: IP Logged
If you will find way how to simulate it, write me please.
Can you test 32b version? Simple replace your 64b version.
Edited 1 time(s). Last edit at 2021-10-12 17:10 by pspad.
