You are here: PSPad forum > Bug report / Hlášení chyb > Re: Version 687 - search in files result clicking
Posted by: Extranjero | Date: 2021-10-11 06:26 | IP: IP Logged
Doing 'search in files', clicking in the results only once (after restart PSPad) behaviours in the correct way (opens the file containing the and goes down to line), second and more times go to the 'correct' line in the current/actual file, doesn't open the file with the found search result.
If the result line of the result-file is greater than the total line number of the actual file, it goes down to the end of the actual file, what not only causes not showing up what u want, but also leads to a certain confusion because in several cases u end up in other lines/at the end of the current file ...
Note: this is a new behaviour in version 687, in versions before it worked well.
Posted by: pspad | Date: 2021-10-11 07:31 | IP: IP Logged
It was reported and it's fixed already. Wait for next build please.
I will try to publish it regularly again.
