You are here: PSPad forum > Bug report / Hlášení chyb > Re: File Open dialog opens in bottom-right corner of screen
#1 File Open dialog opens in bottom-right corner of screen
Posted by: swbrains | Date: 2021-09-11 15:07 | IP: IP Logged
Not a major issue but different than prior versions and somewhat annoying:
After starting PSPad, using any of the normal methods to open a new file (File->Open, CTRL+O, toolbar, etc.) opens the file open dialog in the bottom-right corner of the desktop, whereas it used to open it near the middle of the desktop.
#2 Re: File Open dialog opens in bottom-right corner of screen
Posted by: pspad | Date: 2021-09-11 15:27 | IP: IP Logged
Open dialog is Windows system business. I think, operating system remembers it's position and opens it on the last used place. Move it where you want and open file. It should remember place for future
