You are here: PSPad forum > Bug report / Hlášení chyb > Re: Block type: COLUMNT does not work
#1 Block type: COLUMNT does not work
Posted by: sykyman | Date: 2021-08-17 10:39 | IP: IP Logged
When i switch the block type to "COLUMN", the block is not changed and it is not possible to mark columns. In the menu is "NORMAL" type checked.
#2 Re: Block type: COLUMNT does not work
Posted by: pspad | Date: 2021-08-17 11:20 | IP: IP Logged
hello
There are two possibilities how to select column block. As default is option, what select column block with Alt+mouse, same style as in other office applications.
When this option is active, aby mouse click without ALT key change block back to normal.
If you prefer change block type and select block with mouse, you need to deactivate option in program settings / Editor 1 - []Alt sets column mode
You can always select column style and select block with shift + cursor keys
