You are here: PSPad forum > Bug report / Hlášení chyb > No mapping for unicode character exists...can't open file
Posted by: Mog | Date: 2021-07-27 14:39 | IP: IP Logged
Hi!
Got this error when trying to open an include:
This is a new error which I haven't experienced before. The whole include script is coded in pspad, so this is something new in the version I'm running, which is 5.0.7. 534.
That include contains many special chars in a filename converter function.
Any remedy for this?
Regards,
Mog
Posted by: pspad | Date: 2021-07-27 15:12 | IP: IP Logged
It can happen w.g. when utf-8 encoding contains no unicode chars - typically db export, result ofany exporters e.t.c
Download new 5.0.7 build, it should be able open your file.
If it doesn't help you, send me your file to support mail (if possible)
