You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPad terminates: access violation
#1 PSPad terminates: access violation
Posted by: catwaezle | Date: 2021-07-16 08:14 | IP: IP Logged
Hello to all , im using PSPAD long time.
since 1 year not i get often an access vialation exception
and the pspad must terminate.
Message: Access violation at address: 0067A44A in module 'PSPAD.exe'. Read of adress 000000160.
my PSPAD is 5.0.6
OS: WIndows 10
I hope somebody can help me
#2 Re: PSPad terminates: access violation
Posted by: pspad | Date: 2021-07-16 08:15 | IP: IP Logged
hello
Visit PSPad forum and download the latest build 5.0.7 from PSPad
developer forum: www.pspad.com
Replace existing files with content of archive.
This build contains fix of your problem
#3 Re: PSPad terminates: access violation
Posted by: therium | Date: 2021-08-05 10:57 | IP: IP Logged
Programmer here. This has been a problem for several years on Windows 8 and Windows 10, although the problem is not as bad under Windows 10, it still happens. This is a very difficult issue to track down that is why the author is asking you to try the dev version of the program, v5.0.7.
