You are here: PSPad forum > Bug report / Hlášení chyb > List index out of bounds (1453) - 64bit app creash
Posted by: | Date: 2021-07-09 14:16 | IP: IP Logged
The error was triggered by clicking "Apply" in Program Settings.
I can replicate this error in each attempt - any change (even checking and immed. unchecking the option, then clicking "Apply") will cause crash.
Quite often the app crashes when switching or closing tabs with XSL or XML content. (with Access violation err.)
All related to 64bit version. I used 32bit for some time with nearly no crashes. Something rotten in 64bit one?
Thanks for maintaining the app!
Martin
Exception class:
Exception address:
Stack list, generated 09/Jul/21 4:14:02 PM
(See forum.pspad.com)
Program : C:\Program Files\PSPad editor\PSPad.exe 5.0.7 (647)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz, 3190 MHz MMX
Display : 1920x1200 pixels, 32 bpp PPI: 96
Skin : Windows
Active Controls Hierarchy:
TfSettings ""
Edited 1 time(s). Last edit at 2021-09-13 08:14 by Stefan.
Posted by: pspad | Date: 2021-07-09 19:54 | IP: IP Logged
Visit PSPad forum and download the latest build 5.0.7 from PSPad
developer forum: www.pspad.com
Replace existing files with content of archive.
This build is able fix corrupted PSpad.ini - your case.
