You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
#1 PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: SF | Date: 2021-06-08 10:41 | IP: IP Logged
you can no longer copy / paste anything with Ctrl-C / Ctrl-V , but only with TXT-Files ?
Edited 1 time(s). Last edit at 2021-06-08 10:43 by SF.
#2 Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: pspad | Date: 2021-06-08 10:43 | IP: IP Logged
You can, but shortcut must be assigned.
Are yiu sure you didn't clear up short cut assigning in the program settings / keymap?
On the same place you can set the default shortcut settings.
#3 Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: pspad | Date: 2021-06-08 10:45 | IP: IP Logged
SF:
Another possibility, why paste isn't available ir file open or set as Read/Only.
You see it in title and youcan change it by clicking on the "lock" button on toolbar or in the menu file
#4 Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: SF | Date: 2021-06-08 10:46 | IP: IP Logged
strange: it don't work with *.TXT-files , with *.f -files it works
Edited 1 time(s). Last edit at 2021-06-08 10:47 by SF.
#5 Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: SF | Date: 2021-06-08 10:49 | IP: IP Logged
i've checked the fileatributtes -> it's not R/O
#6 Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: pspad | Date: 2021-06-08 12:12 | IP: IP Logged
Attribute is initial state only. You can any file lock manually to prevent accidental modification.
Again, state of toolbutton with 'Lock' icon is pressed or not? Or menu File / Read only?
If you enabled save file state options, PSPad remembers this settings.
And oposite, if file has R/O attribute, you can unlock it manually in PSpad and save it. PSpad will remove R/O attribute, save file and set R/O attribute back.
#7 Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: Extranjero | Date: 2021-06-09 11:51 | IP: IP Logged
noticed that functionality of some keys disappears sometimes and than the famous 'access violation' happens ... eg. backspace key ...
#8 Re: PSPAD v 5.0.7 (649) -> no Clipboard - functionality
Posted by: pspad | Date: 2021-06-09 11:59 | IP: IP Logged
Extranjero:
I need as much info as you are able to provide. In ideal case how to simulate it
