You are here: PSPad forum > Bug report / Hlášení chyb > Toolbar icon set choice not remembered in 5.0.7 (647)
Posted by: klr98298 | Date: 2021-06-02 17:28 | IP: IP Logged
It seems that the recent version 5.0.7 (647) does not remember the toolbar icon set choosen by the user across application restarts. It always falls back to the "PSPad" default icon set.
For example, if I select a different icon set (such as "Silk") and save the preferences. Although my selection is correctly saved into the PSPad.ini file, when I exit and launch the application again, the toolbar icons go back to the default "PSPad" theme.
Regards.
Posted by: pspad | Date: 2021-06-02 17:45 | IP: IP Logged
Thank you for report, I will check it.
Posted by: pspad | Date: 2021-06-03 05:08 | IP: IP Logged
Problem found and fixed
